Question about Car Audio & Video
Central locking not working on peugeot 206, so got 3 new motors for each door and boot, worked for 5 mins only on driveres side and boot, but not on passenger door.Used car next day and central locking not working, had to use key to unlock. All the indicators flash when fob is pressed so its not the battery on key. Hope someone can help. Thanks
    Problem Solver:
  • 12 Answers
It seem that you have a relay on the control unit with burnt contacts or a bad connection from the control unit to the solenoids. I will opt for the relay on the control unit. Try replacing the control unit
Posted on Nov 19, 2009
On my 1999 Peugeot 206 central locking is bouncing back up. Why can't I lock it manually?
Try checking the tailgate allignement / shutting correctly as this will auto open the locking request from your key/bipper, if the boot switch is not fully operated,
Apr 30, 2015 | 1999 Peugeot 206
Peugeot 206cc central locking
Have you tried to disconnect battery terminal and wait for 5 minutes before connecting again to check the remote locking?
Dec 31, 2017 | Peugeot 206 Cars & Trucks
I have a peugeot 206 cc and the boot sensor says boot is open when it is closed
central locking isnot working because the boot cant lock change the boot sensor wswitch then central locking will work all good
Aug 19, 2012 | 2004 Peugeot 206 CC
Peugeot 206 central locking wont work when i use the button it locks then opens again and will not lock all doors with the key
you have a faulty central locking motor you need to unplug them one at a time and try locking as you unplug each one (leaving the rest of them pluged in)
let me know if this helps
cheers
Sep 18, 2010 | 2005 Peugeot 405
When I press the remote on my Peugeot 206 (1998) central
the "unit"is inside the rear door(each door has its own)and the reason 206 didnt come up is this is primarily an American website but as i live in the uk.....you could spray wd40 into the lock mechanism,may be cheaper than replacing reciever.
May 01, 2010 | 1989 Peugeot 405
My daughters central locking on her 2000 peugeot 206 is working sometimes but unlocks itself again alot /most of the time at times when i try to lock it a ticking/clicking sound comes from the panel below...
Yes it is a relay
Is water getting in the central locking relay? sounds like it, remove it dry it...........open it and get the water out if nessesery! then stop the leak or re-locate the relay away from the water!
also can be worn lock in the drivers door or bad door actuator (MASTER)
All quite easy to fix don't worry too much!
Have a good one......Bruce
Mar 10, 2010 | 1987 Peugeot Liberte
1999 Audi A3 1.8T Electric Windows and Central Locking Won't work
will your passenger door open with the key and is it just one side that your windows are not working or both. if its just one side it might be your regulator motor in the door thats not working if its both it might be your central locking pump usually in the boot. however if both of them are working fine it could be that your key needs reprogrammed however i think the 1st 2 are more likely to be the problem.
Jun 24, 2009 | 2002 Audi A4
Central locking / door locks fault
http://www.honestjohn.co.uk/forum/post/?t=69400
May 02, 2017 | Peugeot Liberte Cars & Trucks
Peugeot 307 1.6 petrol central locking problem
leave ign off with key out 3mins disconnet battery 5 mins reconnett and press lock/ unlock repeatedly until locks cycle through to re sync try this any probs come back to me
Dec 25, 2008 | 2005 Peugeot 405
Car Audio & Video Logo
819 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
