Question about Linksys Wireless-G Broadband Router
Trying to connect to xbox live but its saying can't connect to static i.p address, and asking for my dhcp settings?
    Guru:
  • 1,738 Answers
Log into you router and tell the router to by the dhcp server.
Posted on Nov 20, 2009
Cant get xbox live because it keep asking for an ip address dont know how to fix this
It sounds like it can't get an DHCP lease from your router. Go into your router settings and permit it to connect to (make DHCP leases to) this additional device so it can get online.
Jun 06, 2011 | Microsoft Xbox 360 Console
How can I play with two xbox at the same time? Right now when both are on xbox live one has a strict NAT and the other is open how do I set up my router so both can play with open NAT?
NAT (Network Address Translation) allows your router to use one IP address with your ISP, but assign internal IP addresses to your devices using DHCP. When you refer to "strict NAT" I have to assume you mean that the device has a static (set) IP. If you want them both to work at the same time, you'll have to set each xbox to accept DHCP addressing (ie., dynamic IP addresses) and make sure your router is set to perform as a DHCP server (which it probably is...that's the default).
Dec 29, 2010 | Arris WR850G Router (DHWR850G)
How do you set up the xbox to wireless connection
Turn on the unit without a game CD in the drive; this brings up the main Xbox menu or “Xbox Dashboard
Using the joystick’s control pad, go to“Settings” then click the “A” button on the joystick
From the “Settings” menu, go to“Network Settings” and click the “A” button on the joystick
The “Network Settings” window has various options to connect the Xbox to a network or directly to an ISP using PPPoE. Click the “A” button to select “IP Address
The Xbox defaults to DHCP (Dynamic Host Control Protocol). If there is a good network connection to your HomePortal, you should see the IP address fields populated. If the Xbox was previously configured for a static IP address, click the “A” button on “Configuration” and select “Automatic”. Click the “A” button to accept the changes or the “B” button on the joystick to go back up one level in the menu
The “DNS Servers” (Domain Name Service) is set to “Automatic” by default; you may need to reset it to a previous static setting. Simply click the “A” button and change the setting to “Automatic”, then click the “A” button to save the changes
PPPoE (Point-to-Point Protocol over Ethernet) is turned off by default; if the Xbox was connected directly to a DSL modem before the HomePortal was installed, you need to change it back to “Off”. Simply click the “A” button on the “Configuration” menu and change to “Off”, then click the “A” button to save the setting.
The “Advanced” tab has the configuration menu for the Xbox-branded wireless adapter, where you change the DHCP Host Name and spoof the MAC (Media Access Control) address if necessary
Verify the settings; click the “Connect” option and click the “A” button to test the network connection.
The system now checks the physical connection, verifies the IP and DNS addresses then tests the connection to the Xbox Live service. If everything is ok, the test shows “Connected to Xbox Live
May 20, 2010 | Microsoft Xbox 360 Elite Console
When testing the connection for xbox live it can't find the IP address.
Xbox 360 Connection Tests: IP Address
This test verifies that your Xbox 360™ console has a valid IP (Internet Protocol) address.
If your console does not pass this test:
Confirm that there are no other devices on your network with the same IP address.
If you are using a router or gateway, verify that it is configured to assign IP addresses to network devices (DHCP-enabled).
If you are connected to a router, make sure that your console'sEthernet cable is not connected to the router's LAN port rather thanits WAN port.
If you are connected directly to a modem and your ISP (Internetservice provider) requires PPPoE settings, verify that your PPPoE username and password are correct. If your ISP doesn't require PPPoEsettings, remove the PPPoE user name and password settings.
If you are connecting directly to a modem and have replaced a devicethat was connected to your modem with your Xbox 360 console or anotherdevice, turn the modem off and back on before connecting the newdevice.
If you are using a static IP address from your ISP, verify the address with a your provider.
If your console is connected to an ad-hoc network (in which devicesare connected directly to each other), it will probably not pass thistest. If your IP address is assigned automatically and your ad-hocnetwork does not include a DHCP server, this does not indicate aproblem. The test is properly reporting that a DHCP server could not becontacted. Xbox Customer Support does not support the use of ad-hocnetworking to connect to Xbox Live.
If you're using an ad-hocnetwork without a DHCP server and you can't connect to Xbox Live, checka different diagnostic test for the root of your problem.
This comes from http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/troubleshootliveconnection-testipaddress.htm
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 31, 2009 | Microsoft Video Game Consoles & Games
Change NAT to open
You should first reserve an IP address for your Xbox in your router DHCP server settings. If it is not possible to make a reservation, you should assign a static IP to your Xbox and excluse that address from the router DHCP server.
Then, you should set DMZ to point to the IP address you just reserve for your Xbox.
You should be set!
Please do not forget to rate the quality of my support in FixYa.com. ;)
Mar 27, 2009 | D-Link DSL-G604T Wireless Router
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
HP Officejet printer
i assume that your printer is connected to a network. if so, it could be that the printer is set to use dhcp for the ip address. and if that's the case, it's better to set the printer to use static ip address since there would come a time that the dhcp server (a router most of the time) would provide another ip addresses to all the devices connected to it. that could be the reason why you are getting a "no connection" message (disconnecting and reconnecting it at times would solve the problem temporarily).
here are the steps on how to set static ip on the printer using a windows computer.(Note: the installation cd can automatically assign a static IP address as long as the printer does not obtain a dynamic (dhcp) address)
- boot up your computer the normal way so it'll get an ip address from your dhcp server
- then turn off your dhcp server so that the printer will not get any ip address via dhcp
- reset the printer to set its factory default configuration (with no dhcp address)
* unplug the printer from the power
* plug the power cord back in while holding in the printer’s
report button (it will try to find a dhcp server; after about three
minutes of no dhcp response, the printer will default to a static ip address of 192.0.0.192
- then print a configuration page to confirm that the ip address of the printer is set to 192.0.0.192
- then press the report button (wait until IP address is 192.0.0.192 before proceeding. if it remains set to 0.0.0.0, check the network cable connection to the printer and to the network is secure. If some other address appears repeat steps 3 and 4 until the default address appears
- you can now start the software installation cd
*during the installtion, follow these steps:
- select the model of the printer that you are using which is hp officejet before clicking on "next"
- then select "do network settings for me, then press "next
*follow the instructions on the remaining install screens
- the software will pick an ip address in the private 169.254.x.x range (not available on the open Internet) and permanently assign it to the printer. it will also set up a static route to that address in the computer’s printer configuration
- turn the dhcp server back on by turning on the dhcp server by
connecting your cable/dsl modem or dhcp to the network. because the hp now has a permanent static ip address, it will
no longer try to use dhcp server to get an address
- install the software on the other computers on the network who will be using the printer. the installation software will discover the hp printer at the 169.254.x.x address, and will add the static IP address in each computer’s printer configuration
Note: if the installation cd will permit you to change th private ip address from 169.24.x.x, it's better to set it on the same range as of the ip address given by your dhcp server (for example your dhcp server provides ip addresses starting from 192.168.1.100-192.168.1.250, set the printer's ip address to 192.168.1.59-below or any ip address that will not compromise any ip addresses that were already being used by your other devices)
hope this'll help you but if you'll have other concerns just ask me.
ciao!
Jun 28, 2008 | Computers & Internet
My NAT type is on moderate so I cant play Xbox Live
I tried everything and eventually figured this out.  Do this!
Enable DHCP set the start ip to 192.168.1.100, and remove any static IP address on your xbox 360 (have it automatically detect connections)
Set the MTU to 1364.
enable UPnP.
if you are using wrt-dd (if you aren't, you should be)  setup QoS so xboxlive has premium priority.
And you have hit the ground running.  Even microshats own website wont' help you fix this stupid problem.
I promiss this will work ;)
May 16, 2008 | Computers & Internet
Xbox 360
Either the network connection between the 360 and router is not working correctly, or your router is not configured properly for DHCP.
DHCP (Dynamic Host Configuration Protocol) is a protocol that automatically assigns a network address (and some other settings) to your computer....or Xbox in this case. It works like this....when your Xbox connects to the network, it sends out a broadcast packet on the network that looks for a DHCP server. If a DHCP server is present, it responds. Next the Xbox requests its network address and other settings from the DHCP server. Your WGR614 router has a DHCP server function built in, but it may not be enabled. Try reconfiguring the router using the Netgear "Smart Wizard" installation CD and be sure to enable the DHCP capability, if asked.
Jan 10, 2008 | NetGear WGR614 Wireless Router
Xbox live
THINGS TO TRY loadTOCNode(1, 'whattotry'); Direct connection with a modem only loadTOCNode(3, 'whattotry'); 1. If you are connecting to Xbox Live by using a modem that is connected directly into your broadband socket, your IP address settings are obtained from your ISP. Set your IP address in Network Settings to Automatic. 2. If you use a static IP address that you obtained from your ISP, you must manually enter this address in the Dashboard. Contact your ISP for their static IP address if you do not know it. If the IP is not static, continue with the rest of the troubleshooting. 3. Power cycle the modem. 4. If your ISP requires PPPoE settings, verify that you have entered them correctly. 5. If your ISP does not use PPPoE authentication, do not use these fields in the Dashboard. Shared connection with a modem and a router loadTOCNode(3, 'whattotry'); 1. Power cycle both the modem and the router. 2. Try connecting the Xbox 360 console to Xbox Live by using the modem only. This eliminates any configuration problems on the router. • If this setup works without the router, there is a configuration issue with the router. See the router's documentation or contact the technical support group. 3. Verify that your router's DHCP service has been enabled. See the router's documentation or contact the technical support group. 4. The IP address that you entered in the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If your ISP requires PPPoE settings, try to connect with only the modem after you enter the PPPoE settings in Network Settings. • If you can connect, see your router documentation to configure the PPPoE settings correctly on the router. 6. If you are receiving an IP conflict error in the More Info section, turn off all the devices on the network. Try to connect with only the modem and Xbox 360 console connected. • If this works, there is a configuration issue on the routers DHCP server. See the router's documentation or contact the technical support group. Shared connection with a gateway device (combined modem and router) loadTOCNode(3, 'whattotry'); 1. Make sure that the device is turned on. 2. Verify that there is activity with the blinking lights sequence WAN, ADSL, and Internet connected power. Note These names will vary from model to model. 3. Power cycle the gateway device. 4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If you are receiving an IP conflict error in the More Info section, turn off all the other devices on the network. Try to connect with only the Xbox 360 console on the network. • If this test works, there is a configuration issue on the gateway DHCP server. See the router's documentation or contact the technical support group. Shared connection with Microsoft Windows Internet Connection Sharing loadTOCNode(3, 'whattotry'); 1. Verify that you can browse the Internet. If you cannot browse the Internet, Internet Connection Sharing is not configured correctly. 2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer. 3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK. 4. On the View menu, click Tiles. 5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation. 6. Enter manual settings in the Dashboard for IP address, subnet mask, DNS address and gateway: • IP Address : 192.168.0.2 • Subnet mask : 255.255.255.0 • Default Gateway : 192.168.0.1 • DNS server (Primary): 192.168.0.1 • DNS server (Secondary): 192.168.0.1If none of this works you might be banned. If you modded your xbox360 or for downloading game saves from the internet to boost you gamer score. You might be banned!
Oct 14, 2007 | Microsoft Xbox 360 Console
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
