Question about LG Audio Players & Recorders
I have a brand new LG Blu ray soundbar HLB54S and cant get the remote (bluetooth)woofer to work. I have tried the fix in the manual, (press unit stop button simultaneous with remote mute button and unplug woofer from power supply, then plug back in and power up) without success. Any ideas will be appreciated Rob
  • 1 more comment
  • robd722 Nov 20, 2009
    Thanks for the info, I have arranged to take the whole system back to the retailer for testing.
    Many thanks for the advice, will let you know how I get on.
    Appreciate your time and assistance.
    Regards
    Rob
  • robd722 Nov 21, 2009
    Thanks,
    The problem has been fixed, it was basically a translation problem in the user manual.
    In the manual it stated:
    1. press the stop (little square) key on the soundbar
    2. then the mute button on the remote,
    3. soundbar display should read "remate"
    4. then power down
    5. & unplug the woofer
    6. pug in the woofer and power up
    The fix is
    1. switch everything off,
    2. unplug the woofer.
    3. Start the soundbar,
    4. when soundbar on
    5. press the stop (little square key) on the soundbar
    6. simultaneously press mute button on remote
    7. soundbar display should read "remate"
    8. plug in woofer and power up
    9. little blue light on woofer should now illuminate indicating communicating with soundbar.
    Cheers
    Rob
  • 10,594 Answers
Thanks, The problem has been fixed, it was basically a translation problem in the user manual. In the manual it stated: press the stop (little square) key on the soundbar then the mute button on the remote, soundbar display should read "remate" then power down & unplug the woofer pug in the woofer and power up The fix is switch everything off, unplug the woofer. Start the soundbar, when soundbar on press the stop (little square key) on the soundbar simultaneously press mute button on remote soundbar display should read "remate" plug in woofer and power up little blue light on woofer should now illuminate indicating communicating with soundbar. Cheers Rob ============================================== Thank you so much Rob, its great info and will save time in future. Thanks again.
Posted on Nov 21, 2009
  • Shahid Electronics
    Shahid Electronics Apr 26, 2010
    Thank you.
  • Cees de Hommel
    Cees de Hommel Aug 26, 2016
    I followed the abovementioned procedure, but in my case the woofer blue light blinks for several seconds and then turns red. No sound!!
    Cees
  • 232 Answers
Is it paired with the main unit? That would usually be the problem. There will be a pairing procedure like press a hidden button on the woofer, then put the player in search bluetooth devices mode till they connect.
Posted on Nov 20, 2009
  • 643 Answers
Hello, and welcome to Fixya..
The setup process should be relatively simple, and it sounds like you have went through the correct troubleshooting processes..
Im assuming youve tried the fix several times, with no success.
The only other thing that could be hindering the subwoofer from syncing up via its bluetooth connection, is possibly too many other bluetooth devices transmitting in the same room..
If you have a cellphone, or headset bluetooth device in the same room, shut them off when trying to hook up the subwoofer.
This is only an outside shot however, most likely the subwoofers bluetooth transmitter is faulty.
If you have never once been able to get it to work out of the box, then more then likely that is the case.
You should contact the retailer you got it from and turn it in, or else, You can contact LG directly.
http://www.lge.com/uk/tv-audio-video/home-cinema/LG-HLB54S.jsp
Thank you for using fixya, and if you have any more questions, please feel free to ask!
Posted on Nov 19, 2009
  • Tre Elkins Nov 20, 2009
    Ok, thats probably the best idea..
    When they test it, if its done in front of you, make sure they dont try and hook the subwoofer up to a different bluetooth transmitter..
    If it works great, but it will need to work with the blue tooth transmitter they are sending you home with..
    Im assuming that none of the trouble shooting you tried helped out any?
    If you have any other issues after you turn the device in let me know, and we may need to work on reducing the signal interference.
My new remote for an itrak sound Bar model BT0218MO will not work at All? Can someone answer? Ty
iTraK Bluetooth Soundbar with Tuner and Remote, Black ...
www.sportsmansguide.com/.../itrak-bluetooth-sou...
The Sportsman's Guide
Rating: 2.7 - ‎3 reviews
iTraK Bluetooth Soundbar with Tuner and Remote, Black ... You can also wirelessly stream music from your Bluetooth-enabled smartphone or MP3 player to ...
iTrak - Electro Brand
Dec 25, 2015 | Televison & Video
Need code for my LG blu-ray disc/dvd player to set remote for samsung digital tv
You're trying to control your LG blu ray from your Samsung remote? Hold down the power button and press 1 - try that then repeat and try 2 - go all the way up to ''20'' . Or if your manual has LG codes and they don't work - also try the codes for NEC or TEAC
Mar 01, 2014 | Televison & Video
How do I get my LG AKB73375501 to interface with my Blu Ray player?
It has to be setup with blu-ray by setup codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 30, 2013 | LG ELECTRONICS Remote Control AKB73375501...
Purchased LG HLB54S Blu-ray Soundbar - I would like Multiregion
Just got the software to unlock it. It you dont have please let me know your model so I can send you the file. Quite big though.
Jan 09, 2010 | Televison & Video
Sceen is all wavey
http://safemanuals.com/brand-user-guide-instructions-owner-manual/LG
Dec 24, 2008 | LG Televison & Video
922 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
