Question about Honeywell Programmable Thermostat Heater
Ideal boiler no heat to radiators but hot water still working
  • D. Floyd Kolb
    D. Floyd Kolb May 11, 2010
    Check the circulator pump that moves the water through the radiators. It has probably gone bad. The boiler is working and heating so the hot water coils in the boiler are still making hot water for you. If you have a zone valve system then it could be a bad zone valve also. Make sure the thermostat is working and calling for heat and that the relay is that interfaces the thermostat and the circulator is working. As you can see there are a number of possiblities of where the problem could be. You will have to eliminate each one till you find the problem.
  • 36 Answers
Check the divertor head and valve.
sounds like it ist adjusing from dhw to ch.
take head off(remove pi at back,or side pin) and push pin in valve when calling for ch,if it works then the head has gone.
Posted on Jan 25, 2010
What is the best boiler for heating and hot water in Europe for a flat?
I would suggest the Wilford boiler is a great option. In particular, the Zhangjiagang Wilford Boiler as it is a combination boiler meaning it is small, can easily be stored in a cupboard and is economical to run. Get in touch with them to see if it is ideal for you.This brand of pressure hot water boiler is the best choice of transforming of the heating boiler of coal-fired. The horizontal structure of the boiler can absorb the heat with high efficiency ,heat transfer fully, the efficiency of heat transfer can reach 98%, and with good quality of steam, not pollution, no noise ,is the real green and environmental protection product. you can go its website for more
Hot Water Boiler Hot Water Boiler Products Hot Water Boiler Manufacturers...
May 08, 2017 | Miscellaneous
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
I've just moved and the boiler is an Ideal Classic
it should be a fully pumped system , which pumps heating and the hot water i take you have ahot water tank /cylinder for hot water with a 3 way valve on it , hmm set the boiler thermstat to number 5 put you clock /programer to hotwater only,once aday or twice , its down to how much water you need . see if this helps .
Aug 24, 2011 | Heating & Cooling
Does the boiler thermostat control the heat of the radiators as well as the hot water temperature? Does the thermostat control the water temperature and the pump - as our pump seems to be on all the...
There should be a control called an aquastat that regulates the temperature of the boiler. The thermostat will turn on the circulator to start the flow of water through the radiators. If the water coming back from the radiators is very cold, a control will shut off the circulator until the boiler can come up to a predetermined temperature then start the flow of water again. If you have a tankless coil for domestic hot water, you now have a triple aquastat that maintains the temperature for domestic as well as the boiler temp. So yes the boiler thermostat (aquastat) does control the heat of the radiators and domestic hot water. No the pump is regulated by your house thermostat. You should take an amp draw on the boiler and componants to find out what is drawing more electricity than it should and popping your fuse.
Feb 19, 2011 | Heating & Cooling
Ideal classic boiler no heating only hot water when heating is switched to on there is no sound from system but there is when water switched on. the rads upstairs were warming up but not downstairs now...
Hi it sounds like the pump is not working or diverter valve not working check to see if pump is working on ch mode as well as valve , pump could be stuck ,
Apr 12, 2010 | Heating & Cooling
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Hi There, I have an Ideal Response 120 Combi Boiler. Each day the water pressure falls to 0 on the pressure gauge. In order to get hot water and Cental Heating I increase the pressure to 1.5. The Hot water...
I have the same boiler with a similar issue. The water is more than likley leaving the system from the pressure relief valve, which will be routed outside. It sounds like you have lost the pressure in your expansion tank, which is inside the boiler. With the boiler pressure at zero and the power isolated, the expansion tank can be accessed from a panel at the top of the boiler on the right hand side. You will see a valve on the red expansion vessel like the one on a car tyre and can be pressurised with a car tyre air pump. I think from the manual the pressure should be about 1 bar, but it depends on the length of pipework on your system. A competent boiler engineer should be able to sort this out, but it may be that your valve is leaking, or the expansion vessel has failed and the problem will occur again.
Nov 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Heating & Cooling Logo
555 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
