Question about EliteGroup G31T-M7 Motherboard
Compaq presarios s5500uk wont boot up fitted new motherboard,pentium e5200 processor. existing hard drive ide seagate barracuda 7200.7 120 gbytes os windows xp
  • 113 Answers
Check the power supply: unplug the main connector from the motherboard,plug in the ac/mains power cord and switch on the on/off switch if any located on the power supply, locate the GREEN wire on the main connector that plugs on the motherboard, using a small length of wire insert one end into the plug where the GREEN wire is located and the other end into a BLACK wire on the connector. the power supply should power on if it is good: you will see and hear the fan turn on in the power supply. if it is good remove the wire and re-plug it.if it is not good replace the power supply. also check that the 110/220vac swithch is in the correct position for your mains voltage.do you have a floppy drive connected to the system? if so un-plug it and try again,re-check that you pluged the power button switch connector on the mainboard correctly,
Posted on Nov 19, 2009
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
Is Seagate Barracuda 7200.7 80 Gbytes a Sata Hard Drive or not?
Hello and Welcome to FixYa!
Yes this series of Seagate is SATA.
Concerned, Nooh.
Feb 17, 2011 | Seagate Barracuda 72007 SATA 80 GB SATA...
Hard disk Not Detecting (Media Problem)
may be comming steps you solve your problem
check your bios settings on first bootable devices
check your ide or sata cable interfacing mother board correctly
check the power connections
also you want check this one is your os faulty,now you make master &sleve and boot anther hard drive
Jun 12, 2009 | Kanguru - 500GB Disk (Black)...
COMPAQ PRESARIO V2000 BOOT PROBLEM
As much as I would like to tell people do not buy seagate I can't, Most Seagates are having problems, depending on the serial number you might need the firm ware up date. Secret WD is the way to go, better warranty, last longer to.
Feb 21, 2009 | Hitachi (HTS424040M9AT00) 40 GB Hard Drive
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My seagate barracuda 7200 b will not boot up. It has been operating fine for the last 8 months
i suggested you use NORTON DISK DIAGNOSTICS to repair the MBR(master boot record)the master boot record is bad and you can use winXP bootable nto repair the drive by pressing R after booting is completed.but you need to be able to use DOS prompt before you can do this
Jan 14, 2008 | Computers & Internet
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
How to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
May 02, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
EliteGroup G31T-M7  Motherboard Logo
170 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
