Question about RPM Vox 750GB 3.5in USB 2.0 & eSATA External 7200rpm - EXSA-35C-750G5K 750 GB Hard Drive
I split my hard drive so my mac can get it but know my pc wont get it
  • 32,281 Answers
The hard drive must be partitioned and formatted as FAT32 partitions.
If you format it using the MAC, then the PC cannot read this hard drive, but if you format it using the PC then both the MAC and PC will read and write to this hard drive.
Posted on Nov 19, 2009
  • Chris Hingee
    Chris Hingee Nov 19, 2009
    Sorry I forgot to mention this.
    If you format the hard drive so you can use it between the MAC and PC then then hard drive needs to be partitioned in 4 GB partition sizes because FAT32 cannot support partitions or driver sizes larger than 4 Gb.
    If you want to use the hard drive only on the MAC then format it using the MAC or it you only want to use it on the PC then format it in NTFS, (you can still divide up the hard into smaller partition/s)
    I have a suggestion that you can do if you want to use the external drive for both MAC and PC..
    Create 3 partitions - (you can create more if you wish)
    First - Create a 4 GB partition and format it in FAT32 (this allows you to exchange data between the MAC and the PC.
    Second - Create a 370 Gb partition for the MAC - format it using the MAC OS.
    Third - Create the remaining disk space 376 Gb partition and format it using the PC in NTFS file format (NTSF can support drives or partitions up to 16Tb).
  • 3,153 Answers
You could invest in a program called MACDRIVE that allows PC's to see mac formatted drives.
Otherwise I would format it as a PC drive only using the FAT 32 sysytem that AFAIK macs can also still see.
http://www.mediafour.com/products/macdrive/
Hi, I bought a Seagate GoFlex a couple of days ago and successfully backed up my Mac at home. However, when I went to use the GoFlex on my PC at university, the PC was not reading the goflex. Thanks.
Did you reformat the FreeAgent drive when you backed up the Mac? If you use Time Machine or other backup software for the Mac, you had to reformat the drive. If you want the PC to read the disc, it must be formatted in a FAT32 or NTFS file system. The Mac OS formats discs in the HFS+ (extended hard drive format) system.
Unfortunately, if you reformat the disc to a Windows compatible format, you will lose your current backup. The drive will be as a large media transfer disc but not for the backup images. This site, http://www.cs.ubc.ca/~pcarbo/macnexstar.html , has information on splitting the hard drive into two partitions, one HFS+ and one FAT32. Then you could have your backup on one part of the GoFlex and still transfer files from the Mac to the PC and vice versa.
I hope this helps.
May 18, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
My mac i have has been out of power for a while, when i finaly charged it up, and turned it on, it showed a folder that switched between a question mark (?) and a light blue and dark blue face that had a...
Your mac can't find the operating system. Re-install the operating system on the hard drive. Also, could mean the hard drive has given up the ghost. Get a new laptop hard drive ATA/IDE 5400 RPM 2.5" are the specs you need. It the specs say SATA, then you got the wrong hard drive.
Sep 02, 2010 | Apple PowerBook G4 Mac Notebook
External wont open on mac
if you have used the hard drive on a windows pc some format types cannot be recognized by mac
follow these steps to make it usable by mac and windows
*THIS WILL DELETE ALL FILES ON THE EXTERNAL HARD DRIVE AND DOE NOT ALWAYS WORK
Go to Finder -> Application -> Utilities
Double click for Disk Utility
Select the external Hard Disk you wish to format at the left column
Click on the Erase tab
At the “Volume Format” select “MS-DOS File System”
If you confirm to format your hard disk for mac and windows, Click on “Erase” button.
Pop up window will ask to verify the erase procedure. Click the erase button again in the window to start the erase process.
Once the erase process finish, your external hard disk may be able to use in Mac and Windows.
Mar 20, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
My lacie external drive wont transfer my data from a mac to a pc
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Feb 13, 2010 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
Cant format my Hard drive to work with mac and pc
Unfortunately when you format a hard drive it deletes anything on it so if you did this after putting the documents onto it they are now gone.
Jan 30, 2010 | Western Digital Passport 320GB External...
I backed up my apple mac osx onto a lacie 320 gig
If its a pc running a different operating system then it wont know what the files are.
Jan 21, 2010 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
It wont pick up on my hp computer it was my friend and he had in his mac computer
If the hard drive was formatted on the MAC then the hard drive need to be reformatted using the Windows. If you format as a primary drive in FAT32 then the MAC can read and download files on this external drive so that a Windows PC or laptop can read. These files can be exchanged between MACs and PCs.
Oct 10, 2009 | Western Digital My Book Home Edition 500...
I plugged my seagate into my mac OS and backed it up first, then went to my pc running windows xp and tried to locate the seagate drive and couldn't. Can I only use the Seagate on one machine or another?
If you are planning to use the Seagate Hard Drive on a PC and MAC better format it on your MAC Computer thru disc Utility and choose MS-DOS. This should solve the problem.
Mac has the ability to recognize a FAT, NTFS and MAC File System for the hard drive but the PC Computer cannot recognize MAC File System.
Check on your mac the File system of your hard drive.
MAC OS Extended
MAC OS Extended (Journaled)
If this is the file system then you now know that it will not be read by PC.
Also formating it with the use of PC will only result in an NTFS File System, and it can be read by Mac but it is only in a Read Only mode. You cannot copy paste or even erase on the drive having an NTFS on a MAC.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
How can i get get WD "my book" hd to also work with windows
Some solutions possible:
(Optional: - First split the video in chunks <2GB to make them more compatible with older filesystems and networking technologies)
A) Copy the file over the network (e.g. using Windows Sharing on the Mac, or using File and Printer Sharing on Vista)
B) Try to do it via the MyBook.  This means the Mac must be able to write something and Vista must be able to read it.  You say you've "set up" the MyBook "for my macbook pro".  How did you format it?  What filesystem?  Mac OS Extended (HFS+) with Journaling?  In general, you need to install something on Vista to read the Mac's filesystem format (HFS+), or on the Mac to write a Windows format (probably best to use NTFS).  Examples of software like that are:    (Win) MacDisk <http://www.macdisk.com>, MacDrive <http://www.mediafour.com/products/macdrive>    (Mac) MacFUSE with NTFS-3G <http://macntfs-3g.blogspot.com/>       or Paragon NTFS <http://www.paragon-software.com/home/ntfs-mac/>
B2) If you've formatted the MyBook as FAT32, you're lucky.  Just split the movie file in chunks <2GB, copy them to the MyBook, copy them from the MyBook in Vista and join the chunks again.
(for splitting you can use e.g. HJSplit and its compatibles <http://www.freebyte.com/hjsplit/>) (also check e.g. "NTFS on your Mac two ways" <http://www.tuaw.com/2007/11/19/ntfs-on-your-mac-two-ways/> for an alternative explanation.)
Jan 29, 2009 | Western Digital MY BOOK HOME 1TB EXT...
RPM Vox 750GB 3.5in USB 2.0 & eSATA External 7200rpm - EXSA-35C-750G5K 750 GB Hard Drive Logo
195 people viewed this question
Top RPM Computers & Internet Experts
terminalcon
JonSnell Electronic
JonSnell Electronic
Are you a RPM Computer and Internet Expert? Answer questions, earn points and help others
