Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Model 6400AEW Dryer bought 2003
A baffle is loose and you say to lift top..How do I lift top?
  • 2 more comments
  • Anonymous Jan 20, 2008
    How do you get the dryer open? I've got a thumping or banging noise when the drum rotates, both when the drum is loaded and when it is empty. I need to get inside to find the problem, but can't figure out how to open the cabinet. I'm sure there's an easy way, but I can't figure it out.
  • Anonymous Feb 16, 2008
    I need to tighten one of the fins on the dryer drum. To do so I need to lift the top of the dryer up for access to the drum. How do I lift the dryer top up? I see a plastic latch mechanism just back from the front corners of the dryer when I pry up on the dryer lid. How do I unlatch them?
  • Anonymous Nov 03, 2008
    There is a finn loose on the inside of the dryer and I cannot access the drum. How do I remove the top ?
  • Anonymous Apr 27, 2009
    Mine went loose too. I bought mine in 2002. I have a warranty, but who wants to pay $50 service call for a fin being loose?
On my 2006 Maytag Atlantis the top is held down by 4 screws 2 under the front and 2 on the back.
To remove the 2 on the front you need to remove the screws in the door and remove the door and front panel, than remove the 2 screws. The 2 screws on the back hold a white plastic fastener. After removing the screw, pry the bottom of the plastic fastener with a flat head screwdriver. Than with a very thin screwdriver or a thin pry bar wedge it under the top cover and just pop it off. Take care to not scratch your dryer while prying the plastic piece off.
Good Luck
Posted on Nov 16, 2008
    Sniper:
  • 65 Answers
Keep prying up the plastic will release
Posted on Feb 18, 2008
6ya staff
SOURCE:
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Inside the drum, one of the metal things is loose. It appears that it is held on with screws, so they are probably loose. Could you tell me teh easiest way to access the outside of the drum so I can...
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and tighten the baffle screws. But before the top cove can be lifted, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the baffle screws are on top to tighten it. Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
1 of 3 fins on inside is loose & hanging by 1 screw.
Access to the bottom of the baffles for tightening the screws requires the lifting of the top cover which also requires the removal of the front panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Rotate the drum until the baffle screws are positioned on the top for tightening.
May 15, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Need to repair loose Baffle on Maytag Electric Dryer MDE7675AYW
On this model you will see 4 phillips screws in the recessed area when the door is open. 2 on each side. Take the 2 on the right out and then the 2 holding the hinges to the cabinet. Remove the door and then pull the front panel off by pulling toward you. Then you will see 2 screws holding the top down. 1 on each side near the top. Remove these and the top will lift back resting against the wall. From here you can get to the baffles. Good luck and thanks, Rick
Feb 28, 2010 | Dryers
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
How do you lift the top on a 2003 Maytag Atlantis?
remove the door and the oppins screws from the fron panel, the panel will fall foward revealinga few 5/16 screws to release teh top assy
Mar 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Scraping sound on left side as it goes around
You need to replace the tumbler guide rubber wheel. I would suggest to avoid further issues, replace all base guides.
It requires dismantling the Dryer.
e
Dec 17, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
MDE 6200 AYW Maytag Atlantis broken baffle
To lift the top and access baffle screws, proceed as follows;
1. Remove door hinge screws from cabinet. Door can remain in place.
2. Remove screws and plastic retainers opposite door hinge
3. Grasp each side of the top front panel and pull forward. Lift to remove panel
4. Remove lid retainer clamps from each front top corner.
5. Lift top to access drum baffle screws.
If you need further assistance, let me know
Regards,
reg501
Jun 30, 2008 | Dryers
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
451 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
