Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Hi i have WD external hard drive which is not working , i also hearing cliking on it so do u think it can be repair
  • 32,281 Answers
A clicking noise from a hard drive is a sign that the hard drive is faulty. The read/write head is banging back and forth.
I doubt you will find anyone who repairs hard disks, especially if the disc platters are scratched or damaged.
Your best bet is to replace the hard drive in the adapter case.
Posted on Nov 19, 2009
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
  • Project NOMAD
    Project NOMAD Nov 19, 2009
    SPECIAL NOTES
    USB flash drives can fail for no apparent reason.
    Sandisk Cruzers are especially bad for this.
    USB hard drives should be treated with extreme care.
    This is a real hard drive ! and knocks and bumps can quite literally kill them.
    Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
    Known as "The Click Of Death"
    Problem Solver:
  • 5 Answers
No it means you have dropped it or it has been subjected to trauma and is damaged.
it will be cheaper to get a new one rather than repairing it.
Dropped wd external drive & now not recognized by pc
Unfortunately hard drives damage extremely easily. Think of it as an old fashion record player. The needle (head) most likely damaged beyond normal repair. I had fail with less than 6 inches onto **** carpet. Sorry.
Aug 27, 2012 | Western Digital Passport Computers &...
I have a new WD Elements 1 TB external hard drive to just save all my pics onto. I plugged it into the USB it installed drivers and I started copying over years worth of pics. Then it got real slow then it...
> I have a new ... external hard-drive
If it is less than TWELVE MONTHS old, then its WARRANTY is still valid.
EXERCISE the warranty to get it repaired/replaced at _minimal_ cost to you.
Mar 31, 2011 | Western Digital My Book Essential 500GB...
Hello I have one of these drive and I dropped it couple of days ago. The USB port came off. Now it is working but the computer can't show it in "My Computer" and in disk management it shows I...
Hi &and welcome zhah_de !
The internal connection of your unit is probably defective but you could first try a recovery tool , from here for instance http://www.geckoandfly.com/3163/crashed-hard-drive-hard-disk-data-recovery-software-tools-and-service/
Otherwise , extract the drive from it's box ( box will probably be lost ) and connect it right inside your machine or inside any other healthy desktop to the appropriate interface ( IDE or Sata ) .
I think this would work .
Bets regards .
Best regards .
Feb 17, 2011 | Western Digital My Book Essential 1TB...
I can not open my maxtor 160gb, all I can hear is cliking coming from it
Sounds bad but have you tried using Seatools, which is a free download?
Sep 14, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Hi, my WD hard drive is connected to my macbook, but can't access
check under the system profiler which can be found in the applications folder and then in the utilities folder. See if under usb whether the drive is showing under there. If it is, open up disk utility and use the verify disk to see if there is a problem with the drive, if there is use the repair disk to repair it.
Other things to check try a different usb port on the macbook or a different usb cable.
Hope this helps
Oct 21, 2009 | Western Digital 250GB MyBook External USB...
My computer won't recognize my wd my book 500g hard drive. I think it overheated and now is making noise (internal relay switching) It sounds like it's trying to turn on and off but it is on!! What can I...
There can be 3 possible problems since you hear the clicking sound. 1 is that the drive is not receiving enough power from the power supply and it is attempting to turn on. 2nd is the controller board is damaged and 3rd is the drive itself is damaged. From my experience with WD external drives. the 3rd is my best guess. One thing you can try is to buy an external chassis for the hard drive and take the hard drive out of the My Book and put it in the chassis to see if it works. Get one from a place with a good returning policy would also be good as well
May 06, 2009 | Western Digital My Book Essential Edition...
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
WD Elements 500 GB
Hi bobo08,
I'd first check to see if the drive is working correctly with some utilities that WD provides, then once you determine if the drive works, you can either return it the retailer or it's working correctly by using these utilities. Here's the link to that drive. HERE
Good Luck
Mark
Jan 01, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
270 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
