Question about Cameras
Hi there, I have a nikon D50 camera and the inbuilt flash unit does not work any more.... it pops up in dark conditions bu tthen fails to fire. The camera will adjust the shutter speed as if the flash was turned off, and the flash doesn't work in any flash mode or any function mode. Could it be the bulb perhaps? I have reset the camera as well to no avail. please help! thanks :)
  • 643 Answers
Hello, and welcome to Fixya..
This is a very common and known issue with the D50 camera by Nikon.
Some buyers flash only works once and then quits.
Its due to the speed of which the flash pops up, it literally breaks the connections on the inside of the camera for the flash itself.
As far as fixing it, there isnt anything you can do personally..
However, Nikon is fully aware of this issue, and they fix the issue for free.
To request a free repair, please go here
http://form.nikonimagesvcapprove.com/
Fill out the form and then return the camera to be fixed. Or, you could purchase and external flash like the SB 600
They sell them here
http://www.amazon.com/exec/obidos/ASIN/B0002EMY9Y/kenrockwellcom
My recommendation is to turn the camera in to NIkon first.. But keep in mind, the flash issue is due to a faulty design, so even after its fixed, the amount of time the "fix" will last is debatable.
Ultimately, your going to have to either purchase a different camera, or a reliable external flash.
Thank you for using fixya, and if you have any further questions, feel free to ask!
Posted on Nov 19, 2009
Dropped Nikon Camera Sadness
Hi Al
not sure if i can help here but will try.
Ive not owned the D50 but i have the feeling the highlights function is similar to other cameras in the Nikon range.
On your cursor when viewing an image, just press down on the cursor maybe once or twice to remove the highlights .This is just a pointer for you like the histogram.
Now it seems like you may have damaged the sensor and will not collect enough light.
Try setting the camera to A = aperture priority and take a shot in bright light...no flash.
Are the images still dark ?
If so raise your iso to 800 and shutter speed to 1/250 at F5.6 aperture in mode S =shutter priority and take the shot in bright conditions.
Are the shots still dark ?
Nov 11, 2009 | Nikon D50 Digital Camera
Nikon D50 -flash won't fire
Try pushing the flash forward just a tiny bit. this model of Nikon has a built in problem with the flash popping up too hard. You can also try to "soften" the pop-up action with your finger instead of just letting it snap up into position.
Sep 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
D50 onboard flash deploys but won't fire
Your flash head pivot has come unclipped and has slid back into its hole too far. The problem can be repaired by using an L-shaped paperclip to pull the flash pivot back out to its proper position. First, remove the battery from the camera and bend a 1/8" section of the paperclip to make an L on the end and gently insert it into the hole and pull outward while moving the flash head up and down. It should pop back out and the pin will then be long enough to make the flash switch work. Be very careful you do not push the paperclip too far inside the camera so you don't damage anything inside the top.
If you do not feel comfortable doing this, we can do this repair for $68.50. We do quite a few D series Nikons with this same problem.
Bob
www.CameraRepairs.com
Aug 02, 2009 | Nikon D50 Digital Camera
Flash pops up, but flash closed warning stays
My E5700 did this a couple of times. The fix for my flash was that the unit wasn't actually popping all the way open. I closed it, then manually poppped open the flash and gave it a gentle upward tug. The flash seemed to lock into position -- and has worked fine since. I hope your fix is as simple as with my E5700.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 01, 2008 | Nikon Coolpix 5700 Digital Camera
Nikon D50, digital SLR, I was using my camera at a wedding and the flash just stopped working. The camera thinks the flash is going off - it pops up and takes them quickly but no light goes off.... do...
good day,
it seems that your built-in flash is busted. you can go to your nearest nikon service center and have it replaced. or you can purchase an external flash that you can attach to your unit. when looking an external flash better use a nikon flash, however if you are looking for other brands/manufacturers, just check if it is compatible with your unit.
i hope this will help
Sep 27, 2008 | Nikon D50 Digital Camera
Flash
It may be broken/blown, but there is a way to toggle the flash. There is a button located on the left-front of the camera , just left of the flash and above the lens. Hold it while scrolling the wheel on the right.
Best way to find out if it's broke or not: put your camera on Auto, go into a dark room, and take a photo. If the flash pops up and takes a shot w/o firing, you know it's broke. If it doesn't pop up at ALL, you've probably got a bigger problem
Aug 03, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
FLASH UNIT WON'T FIRE
Those Xenon flash tubes last for a long time. You likely need a new flash PCB (printed circuit board). Typically, the trigger coil is at fault when you get the ready light but no flash
Feb 08, 2008 | Nikon D50 Digital Camera
Built in Flash
I have the same problem on my D50. I found this forum, which sounds like it may fix that problem. I am going to try it out. http://forums.dpreview.com/forums/read.asp?forum=1034&message=22761542
Sep 25, 2006 | Nikon D50 Digital Camera with 18-55mm Lens
Flash out of sync
I just had mine fixed by nikon and it seems as though the problem would come back every now and then. my current solution is to switch over to Manual mode and turn AF assist, AF illumination, and ISO control to "ON" and then then shoot a few shots. Then switch metering to centerweight. take a few shots, it should work correctly, then switch back to AUTO. after that, the flash should fire as normal. I just received my body back about 2 weeks ago, so i hope my "bad batch" flash unit was replaced with a known good one. if not, i don't know what to do.
Sep 18, 2006 | Nikon D50 Digital Camera
Cameras Logo
15 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
