Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
Where do i buy rubber non return valve that fits on the wastepipe that goes on a saniflo
  • 33 Answers
You may not get a rubber one, but you can certainly get 32mm and 40mm non return valves from most plumbing suppliers
Posted on May 10, 2010
Non return valve saniplus toilet
The valve could be defective or could have become clogged.
Dec 06, 2013 | Saniflo & Saniplus& Macerator Pump
The pump in my unit continues to try to pump.This happens around every 30 seconds
The problem is the non return valve probably at the elbow end of the unit. If it is a new unit then i would say the rubber has not been installed and if it is an old unit the rubber has probably become dislodged
Oct 07, 2010 | Saniflo & Saniplus& Macerator Pump
Motor runs contiuously. Non return valve pipe and circuit board have been replaced but problem remains..please advise me..
Which pump model is this? Could be that the pressure chamber may be stuck on the on position. There is a rubber membrane at the bottom of the pressure chamber which turns the unit on and off. The membrane may be warped, a piece of solid may be stuck at the bottom or the micro switch can be stuck on the on position.
Jun 19, 2010 | Saniflo & Saniplus& Macerator Pump
Saniplus- after flushing wc, motor continues to run and run.
climatizarea nu functioneaza in sensul ca nu am aer rece ci doar aer cald
Apr 21, 2010 | Saniflo & Saniplus& Macerator Pump
Sanigrind pump don"t always start on all fushes
certainly indicates that the unit is not holding water (hence not starting on every flush). as you are seeing water in the shower - this is obviously where it is going. It may be that the internal flap (non return valve) is stuck open or damaged. If damaged you can put a new non return valve in your 40mm pipe run where the shower pipe enters the saniflo - about a tenner from most suppliers.
Feb 13, 2010 | Saniflo & Saniplus& Macerator Pump
Bmw 325tds diesel flowing back to tank when parked
usual problem ,valves in injector worn for the fuel pump.easy quick fix this one ,fit a non return valve in the inlet pipe,check flow direction on valve when fitting and evan better as well is another in the bleed off return pipe .valves available from a motor factor or a specialist garage like bosch or lucas ,cut pipe and fit the valve with a piece of rubber pipe to connect the valve in line.or listen to the people who want to milk the golden cow and have the whole injector pump overhauled .
Dec 23, 2009 | 2001 BMW 325
A saniflo ensuite shower room that is
If you mean that it self activates then the non-return valve is at fault by the sound of what you say
Nov 24, 2009 | Saniflo & Saniplus& Macerator Pump
Why does sani best need to be 3 feet from stack if it already has to shoot up at least 6feet and over 2feet
just to prevent against cross flow - you dont want effluent from the stack entering your saniflo pipework- to ensure against this with your configuration, i would fit a non return valve on the horizontal inline, preferrably with a cleanout access just in case!!
Nov 06, 2009 | Saniflo SaniStar SaniPack Wall-Hung...
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
644 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
