Question about Nintendo DS Lite Console
Changed bottom screen tested before putting back
Changed bottom screen on ds lite, tested it before putting back together worked fine, after putting it back together doesnt work no power took it apart again and it worked again tried it a few times strange
  • 51 Answers
Happens sometimes it is one of two things:
1) When you put the DS back together is the ribbon from the top screen wound to tightly as this can cause the ribbon to pull out slightly from the socket on the motherbaord causing the blackout.
2) I have seen this happen only once before! The plsatic of the shell had a small chip where the battery connectors from the motherboard stick through into the battery compartment. THis tiny piece of plastic was stopping the final connection between battery and DS. Drove me mad, did all the usuals checked battery connections etc. Worht a look.
Posted on Nov 20, 2009
The top screen on my DS Lite lights up but there is no picture, the touch screen works fine and so dose every thing ellse.
Chances are the screens ribbon connectior has become loose or the screen has develouped a fault.
If its under warranty then send it in, otherwise you can take it to a local repair shop or do a bit of DIY.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen.
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together and hope fully this has resolved the issue.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
Tip
DS Lite Top Screen Replacement
Has your top screen devlouped a fault or stopped working altogether? Here is my guide to re-connecting a new top screen and fitting a new one.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen. (If you need help taking the DS lite apart then check out my other tips and tricks posted on here).
Screw the DS lite back together, after this you will need to place the plastic sheet with the respective DS lite coloured frame back onto the top screen... The reason you don't put it on any time before that is if you put it on prior to putting the new screen in place you will have great difficulty trying to get it correctly aligned.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
DS lite not working after replacing bottom screen
hi friend,i had the same problem....the small cable that you replaced is probably not placed in the connector properly .when you put it in you might have put it under the connector instead of upon it. retry it ,i'm sure it will work.. good luck
Jul 08, 2009 | Nintendo DS Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Ds lite
sorry to say that your top screen needs completely replacing if it is doing as described!!
the bottom screen and the touch screen are seperate, jus mounted on top of each other, so if the picture works on the bottom then the bottom screen is fine just the touch screen is broken. again i think if the cables/ribbons are in correctly and it isn't responding then it will need replacing!!
Jan 29, 2009 | Nintendo DS Lite Console
Touch screen wont respond
double check that both cable/ribbons are connected properly to the motherboard, the small thin ribbon which curls over the top of the motherboard is the one which powers and reads the touch screen so double check this!!
if this is all in fine then im sorry to say your touch screen is broken and will need replacing!
DS Lite repair worked, but only until I put it back together
You may have some pressure somewhere that it shouldn't be. The electrical tape takes up space, and could be taking space that is not there when the console is assembled. Or you keep knocking a connection loose when you put it together.
Try it while it's on. If the console crashes or dies at any point, whatever step you were in the middle of is probably causing that problem. Just make sure not to get anything in it while you were, and don't touch any electrical parts, in case you accidentally short something.
Dec 19, 2008 | Nintendo DS Lite Console
Ds lite recasing
When you take off the bottom case, and lift up the pcboard and lower touch screen, you'll see the ribbon cable connected there. It's held in place by a black connector that lifts up. Use something like your fingernail and life up on the black part until it releases (it shouldn't take too much pressure to lift it up. Once you do that, the cable pulls directly down and out.
Make SURE what when you put it all back together that you make sure to seat the ribbon cable back in there as far up as it will go. If you put it together and all you get is a bottom screen that flashes and it won't stay charging, I'm 99% sure that it'll be that connection isn't in there far enough.
I had to troubleshoot 2 of mine doing that recently. Found out that it was the cable that wasn't in there far enough. Once I put it in far enough, they worked like charms.
Oct 16, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
NIntedno DS lite bottom screen
IMPORTANT: it is not a grave or expensive problem but to solve this problem you need to dissasemble the intendo DS lite, so you must get some guidance like youtube videos on how to dissasemble the NDS Lite or other webpages with info on dissasembling the unit.
You have to carefully open the console, then check for unplugged flex cables and reinstall cables in the connectors to be sure. Then put the console together without screws to retest the unit and see if the screen is working now.
If not then you need a replacement bottom screen and depending on your abilities to retire the touch pad without cracking it you might or might not need a touch pad.
Take out the battery and charger to avoid short circuits while working.
Good Luck...
Apr 07, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
76 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
