Question about Canon PIXMA MP210 Photo All-In-One Printer
Hi i have a canon MP210 and it is showing E2 and the alarm lamp is flashing. there is ink and paper in it any suggestions??? I can't find the user manual!!
  • 4,041 Answers
E2 – No paper, Paper does not feed error.
How to correct, fix: If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Posted on Feb 24, 2010
Correct loading of ink cartridges. Error E2
When a printer error occurs, the Alarm lamp is lit orange. The number displayed on the LED indicates the type of error that has occurred. Check the error code displayed on the LED and take the appropriate action to correct the error.
E and number (error code) are alternately displayed on the LED of MP210 series.
Error E, 2:
Cause: The machine is out of paper. / Paper does not feed.
Solution: Reload the paper correctly and press the Black or Color button.
This sounds like to simple a solution. Make sure this is the correct error code and it is not followed by another number. If problem persists check that you have removed the protecftive material from the FINE cartridge holder. Unplug the machine from the power source for several minutes. Power up. Hopefully this corrects the problem.
If not, try checking the status of your ink cartridges:
1 Open the printer properties dialog box from Control Panel.
2 Click View Printer Status on the Maintenance sheet.
To confirm the FINE Cartridge information, click the Ink Details menu.
This my give further clues to any problem.
Trust this is helpful. :)
Dec 08, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My Cannon Printer mp210 is flashing a 3-E. The light by alarm is on and it will not print or copy.
3 - E mean paper jamed. watch out inside properly some time paper cut stuck inside and its showing.
Jan 29, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
MY ALARM ON MY MP210 IS ON AN MY COLOR INK FLASHES WHAT DO I DO
Check the status of each cartride by using the ink lamp.
You have 3 lamps
(A) Alarm lamp
(B) Black ink lamp
(C) Color ink lamp
Make sure that the LED is on standby mode.
a) If the ink lamp lights.
Cause : Ink is low.
Action :You can continue printing for a while, but we recommend you have a new FINE cartridge available.
b) The Alarm Lamp lights and the ink lamp flashes .
* If "E, 1, 3 " is displayed on the LED, ink has run out.
Cause : Ink level cannot be detected.
Action : Ink may have run out.
The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected.
If you want to continue printing without this function, press Stop/Resset buttonfor atleast 5 seconds.
Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities.
* If E,1, 6" is displayed on the LED,
Cause : Ink has run out.
Action. Rreplace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress, you want to continue printing, press the Stop/Reset button for atleast 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
c) Only the ink lamp flashes
Cause : The function for detecting the remaining in level is disabled.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Display flashes e2 alarm light blinking won't print or copy
E2 mean reload the paper correctly and press Black or Color key from panel board.
Dec 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
For Canon mp210. Error light blinks. Either E22 or E2
Hi there
This is a Carriage error take a good look at the carriage that the inks are in and see if they are sitting ok and also do the next incise there some thing there stopping it from moving.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 07, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My canon mp140 keep on flashing E and then 2 whats the problem
e2 is no paper, E3 is paper jam, E4 is no ink, E5, wrong ink, E8 waste ink absorber full
Jun 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hello my canon mp210 shows an error E 2 please help thank u
Check to see if your ink carriage is sliding across when you turn on the printer.
If not turn off open scanner to turn and and slight pull to start to reboot cycle.
That is what I had to do with mine when it was flashing E2
Jan 09, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Power and alarm lamp lit error code e 3 flashes indicating a paper jam but no paper is jammed power flashing green 3 times then stays green and alarm lamp flashers orange three time then gos off over and...
Try a hard reset first - Unplug printer from AC power source for a minutes and from PC. After a minute, reconnect everything and power up and see if it works..
Oct 12, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
521 people viewed this question
old marine
old marine
