Question about 10 10 Computer (USB-BF-810) Serial Adapter
Vibrations extreme vibrations at front when braking
  • 32,281 Answers
You are in the Computer section of FixYa.
Are you referring to the braking system of your vehicle?
If so the vibrations under braking conditions could be the disc rotors problem or disc pads with leaking brake fluid contamination.
If the disc pads have brake fluid on them, then the caliper seals need fixing or the whole brake caliper replaced (both sides) and new brake pads fitted.
The brake discs may need machining or needs replacing if machining puts them below recommended disc thickness.
Posted on Nov 19, 2009
Front vibration when braking. replaced both calipers & pads. Any thoughts?
usually a front vibration during braking is a warped brake rotor. if it only vibrates from the front wheels during braking, it's bad brake rotors. brake rotors cost $23.00 each at auto zone auto parts stores. just confirmed that for you. thank you for choosing fixya.com
Mar 17, 2011 | 1991 Oldsmobile Ninety Eight Regency
When I brake even at low speeds 25-35mph it feels like the front brakes are vibrating or thumping in quick intervals.
Your front brake rotors have warped, either due to low thickness, or to extremely high temperature. If due to low thickness, the have to be replaced, if due to high temp, there is a possibility that they can be machined down to an even surface, and still have acceptable thickness.
Jun 27, 2010 | Cars & Trucks
My kia front brakes vibrate and the car shudders
take your car to a brake shop and have the rotors turned if your vibration and shuddering is occurring when you actually apply the brakes.
Mar 03, 2010 | 2002 Kia Sportage
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Steering wheel vibration at 65 mpr after I had master brake cylinder replaced. I have to pull off to side of road and stop car then start up again and problem stops. Can feel vibration in brake pedal when...
check balance of tires; if ok, have rotors refinished or replaced; most likely warped rotors if you can feel it in the brake pedal when braking
Oct 07, 2009 | 2004 Toyota Solara
Had bad vibration in front end of car when brakes applied,installed new rotors and pads,still have slight vibration when brakes applied.
do u feel the vibration in the steering wheel or in the seat,i bet the most vibration was coming out of the front brakes and a little out of the rear brakes,u might want to change the rear brakes if the vibration is still annoying,also were the front wheels torqued to spec when installed?? if not u might end up with warped front brakes again,hope this helped
Sep 05, 2009 | 2003 Cadillac Deville
Steering Vibration (Death Wobble)
HEY I HAVE A QUESTION YOU DONT FEEL THE PROBLEM WHEN YOU HIT THE BRAKES AT HIGH SPEED IF YOU DO THE PROBLEM IN WHIT YOU BRAKES YOU NEED TO DO NEW SURFACE IN YOU ROTORS AND PUT NEW BRAKES
Aug 05, 2009 | 1998 Land Rover Discovery
Honda Odessey 2002 - Rotor brake
Yes, depending on the quality of the rotor, in extreme conditions it can rust out quicker. The brake pad graps the rotor, 'cleaning' it as it stops the vehicle. If the vehicle sits for a long period of time then it is more likely to accumulate rust. If a rotor gets out of balance, (this is what causes your vibration) it needs to be remachined. The rotor can only be machined so many times before it is too thin to use. The rear rotor must be thinner than the front rotor. Since this is a vital part of your brake system, it's money well spent to help insure your safety.
Jun 19, 2008 | 2002 Honda Odyssey
200 jeep cherokee vibration when braking
A vibration when braking can be a few things. Warped rotors are the most common cause, but a damaged ball joint in the front, or excessively worn shock could also be the cause.
Does it vibrate any other time?
Feb 22, 2008 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
Top 10 10 Computer Computers & Internet Experts
Reg Varney
Reg Varney
Level 1 Expert
Are you a 10 10 Computer Computer and Internet Expert? Answer questions, earn points and help others
