Question about Canon FAX-L1000 Plain Paper Laser
Whats the scan platform
Can't send a fax it keeps saying to check the scan platform
  • Canon Master
  • 1,113 Answers
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed roller...al this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Posted on Nov 19, 2009
Canon L120 - What does this error message mean?
Check Scan Platform, means:
The scanning platform is dirty, or not set into scanning position.
Solution
Clean the scanning area, or lift the scanning platform into place.
Nov 26, 2011 | Canon L120 Fax Laser Printer
I have a faxphone l120 every time i try to send a fax is say tx cancelled and goes to check scan platform i need instructions that are dumby proof
Hey! If you take out the cover thats covering the recieving paper,Look in there and u will see a black lever with a green sticker on it!You should see a thin glass covering a whitish area,Push that up untill you hear the clicking sound! Enjoy!
Sep 09, 2010 | Canon L120 Fax Laser Printer
Fax machine
Scan platform is located above paper cover. Its like long rectangle with wite stripe and scaner. In some cases it falls down and the documents from feeder cant came trough.
Push it up back, and should work.
If doesnt works, you have bad main pcb fault.
Jul 14, 2010 | Canon FAX L-120 Plain Paper Laser
Check scan platform
Above paper cover, there is scann platform. Put it back in up possition.
Jun 11, 2010 | Canon FAX L-120 Plain Paper Laser
We have a canon i-sensys L 100 fax machine and it keeps coming up with the error Check scan Platform and we are unable to send faxes. How do we solve the problem.
Ok,Remove the papercover tray, if you look just above the paper tray you will see the scanner,close the scanner by pushing it upwards,and then your problem will be solved.
Mar 18, 2009 | Office Equipment & Supplies
Canon Fax-L120/L100
Check the manual for how to clean the scan platform (glass).
Jul 02, 2008 | Canon L120 Fax Laser Printer
Check Scan Platform
Once run the fax setup wizard from the HP Director and then try to send the fax again.
Apr 24, 2008 | HP Officejet 4355 All-In-One InkJet...
Check scan platform
Two things cause this, a dirty scanner or after the user cleaned the scanner it was reassembled incorrectly Directions are in chapter 8-4 of the “Basic Guide”
Apr 02, 2008 | Canon L120 Fax Laser Printer
Coulnd't send a fax
I had the same problem and called canon helpline.
They said to unplug the machine from the mains, then take out the plastic guard where the paper tray is fitted. There is a lever just above the paper tray. Make sure that it is pressed up completely. Then reconnect to mains.
I tried it and it worked.
Dec 27, 2007 | Canon FAX-L1000 Plain Paper Laser
Caution check scan platform
you need to check the scanning platform that is above the paper tray. it may be loose. you will have to close it properly and hopefully it will start working.
regards,
kumar
Oct 15, 2007 | Canon FAX L-120 Plain Paper Laser
Canon FAX-L1000 Plain Paper Laser Logo
474 people viewed this question
old marine
old marine
