Question about Panasonic Lumix DMC-FX8 Digital Camera
LCD monitor ( light does not work)
Hi
I have a problem in that the light behind the LCD monitor does not work and I can only just see the menu etc
Please can you help
How to fix HP 1955 lcd monitor black spot
Hi
There is nothing to be done except replacing with a new one. Hence do not waste time behind it. As the liquid from the LCD has already leaked inside and it spreads to other parts of the screen also over time.
Dec 06, 2015 | HP Computers & Internet
Hi, i have a samsung b1930n monitor. It's menu
My monitor is getting blank within 3 seconds after I start my system what could be the problem
Jul 09, 2011 | Samsung Monitors/LCD LCD Panel
I have SyncMaster 940nw LCD monitor, which works strangely: screen is often black(sometimes I can see unclear flickering), power indicator is double blinking one time per second. Menu doesn't show up...
The problem is in the inverter board which powers the back lights behind the screen. The cause is bad capacitors that sometimes bulge at the top indicating they are open. The board needs to be changed or an attempt made to repair the old one. Now you indicated a second problem with the menu not coming up, you probably would be further ahead to replace the monitor.
Feb 17, 2011 | Computers & Internet
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
My new 202E 20'' monitor says Monitor Controls Locked. How do I unlock it to change the brightness, color etc please?
Press and Hold the Menu button (which is towards the left of Power button) for 20 seconds until it displays "Monitor Controls Unlocked" on the screen.
Hope this helps !
Regards,
Shuaib
Aug 30, 2010 | Philips 150C4FS 15" LCD Monitor
The monitor will not work. We switch it on and it flashes POWER SAVING MODE and goes dark
hi laura,
you may have to disable the POWER SAVING MODE by using the monitor's menu settings(see front buttons, on older models they're hidden
behind a click-panel in the front of the monitor)
it is the same menu you would use for adjusting the monitor's brightness etc.)
If you still face the problem, do hook it up to another PC and boot up.
Try using the PC with another monitor as well, just to double-check the video card is ok.
If stilll the same prob, it could be broke .
Good luck
Aug 04, 2009 | LG Computers & Internet
CANNOT REMOVE THE OSD MAIN MENU FROM MONITOR SCREEN
The problem of OSD Menus popping up automatically are usually caused due to a faulty switch in the Menu button which is getting switched on automatically.
This menu will not harm the computer but constant OSD menu will most probably lead to permanent damage to the pixels in the LCD screen plus it is a constant irritation to your eyes which are most precious.
This problem can be rectified by replacing the faulty menu switch. Hope this solves your problem Thanks.
Jul 23, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Buttons on the front of the monitor don't work
rosener
Rank:wizard_s.gif Wiz
Rating: 81%, 65 votes
Hi Denise,
Hope this helps; If you can control this before, ask for asisstance in opening monitor chassis with certified technician due to High Voltage Shock risk. Resolder the menu buttons and the control circuits. Resolder also SMPS module driving voltage to control circuit.
Best regards,
you are an idiot i have the same problem several times with this unit too. and it has nothing to do with a burnt wire you ********* stupid ********.
Jan 29, 2008 | TDV Vison TDV FV19B 19" Flat Panel LCD...
Panasonic Lumix DMC-FX8 Digital Camera Logo
41 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
