Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Brand new and just hooked up 1004 when run for a few minutes begins to have a squeaking noise.
  • 1,420 Answers
Remove the two screws on the top right and left sides of the heater. Unplug the wires on the top right front light. Start the heater and listen where the squeek is coming from. Contact your installer for a warranty repair and give them the information where the squeek is coming from.
Posted on Nov 20, 2009
My new nordictrack 1750 is squeaking.
Talk to the manufacturer or take it back. It should not do this if it is brand new.
Jun 10, 2017 | Cars & Trucks
Roper dryer model RES7647KQ2 makings a scraping noise as if there is a coin in the drum that is constantly scraping the side as the drum turns. But there is no coin in the dryer (wish it was that easy). ...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 09, 2011 | Roper RES7646KQ Electric Dryer
When the dryer gets hot, the tumbler begins to make a continous squeaking noise as if there is metal to metal; not a grinding noise. If you allow it to cool down and restart, it doesn't start until it...
Well ya never mention in your question what brand you have but a GE or Hotpoint dryer has a small plastic insert that wears thin over time. It begins to do a squeak squeak squeak type of noise.And that noise is intermittent, on a Frigidaire model the noise would start out low and gradually get worse. The bearing sometimes gets so bad it gets chopped off and the tub falls into the heating element.
Jun 30, 2011 | Dryers
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
Massager squeaks
Zip off the cover and add some talcum powder to the inside cover where the roller make contact with the cover.
May 03, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
My dryer makes squeaking noise just on the begining of circle.After few minutes it stops.What that could be?
there are rollers that the drum rides on that could be doing this,or the pulley that the belt attaches to,some dryers have glides on the front bulkhead or like frigidaire the drum rides on a back bearing that wears down,one more thing to check is the blower wheel,next time send brand name and model number,take out the drum and move the rollers and pulley by hand or try rotating the drum by hand to see if you hear the noise,see if it's in the front or back of drum and go from there
Dec 05, 2009 | Frigidaire FSE748GF Dryer
Broke brand new belt
youve got a pully locking up,all except the crank pully should spin freely by hand if there good
May 25, 2009 | 1988 Oldsmobile Cutlass Supreme
Belt squeaks when AC turns on
Your belt is not tight enough. Are you using the power steering pump to adjust? (right way) or doing something else? Keep tension on the pump and tighten the pivot bolt first.
Apr 30, 2009 | 1995 Jeep Grand Cherokee
Dryer squeaking & Clunking noise
Your particular unit has quite a few things that could be making a real loud noise.....The idler pulley, blower wheel, rear drum rollers, front drum glides. Bottomline is you have to get in there and take the unit apart..vacuuming while there and if the unit is making such a noise, it will be obvious where the problem is.....If I can help further, I am here.......
Eric Campion
Mar 04, 2009 | Dryers
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
141 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
