Question about Fuji FinePix S5000 Digital Camera
Setting auto timer to take a family photo, havn't got an instruction manual not sure of the buttons or the settings
  • 132 Answers
On the bach of it find the meun button and press it and then go to timer and set it from the sec. that you want
Posted on Nov 19, 2009
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
I need to know how to set the time on my model RETP RINGGRIP TIMER
To set the time;
Press and hold the TIME button during the time setting procedure. While holding the time button press DAY to set the correct day and HR to set the correct hour (make sure the am/pm is correct) and then MIN to set the correct minutes. (If you hold down the Day/Hr/Min button for more than 2 seconds it will give a fast run-through)
Dec 13, 2012 | Hardware & Accessories
How do I program the timer to turn on and off at specified times?
You need to program the timer so it turns on-off at specified times.
But first we need to identify your timer for sure.
Have a look at link below.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59203
If your timer does not show, then add a comment with description of timer.
I have extensive files on timers.
Intermatic DT300, GE 15091, and Woods 59203 are the same timer.
Here are instructions for Woods 59203:
Plug timer in until battery is recharged.
If display will not show, then timer battery needs to be plugged into outlet for 1 hour until internal battery is recharged, or timer is bad, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Once display shows, then unplug timer for programming.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Make sure lamp is turned on.
Make sure bulb is good.
If instructions don't fit your timer, then add a comment with model number or full description and I'll post those instructions.
Also you can take advantage of Fixya phone service where expert speaks with you over the phone for a price.
Dec 21, 2010 | RTO Intermatic DT300CL 8.3 Amp Seven Day...
How do I program Woods digital timer 59203?
Link shows all Woods timers and manuals
If instructions below do not match your timer, look through timers on Woods page to identify, and then add a comment.
Manual for 59203
http://waterheatertimer.org/pdf/Woods-59203.pdf
Instructions below are for Woods 59203 & GE 59203 plug-in programmable timer with 2-prong polarized outlet:
Plug timer in until battery is charged.
If display will not show, then timer battery needs to be recharged, or timer may be busted, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Set current time:
Program timer:
Dec 11, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Set timer for the 7-day outdoor timer i.e. 5:00 pm on and 9:00 p.m. off Also set the clock ~ should it be left 'on' for the timer to work? Have lost the manual our programmer
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Dec 05, 2010 | Intermatic HB88RC - 7-Day Programmable...
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Have a globe electric power bar with7on/7off timer- instructions appear pretty confusing, can not get it to function
I cannot find manual for that product. I think it's actually an Intermatic product DT8003, but I can't find that manual either.
1) If you post the exact wording from the manual where it gets confusing, it would be easier to help ... and typing out the instructions on your part might help you solve the problem
2) If I had to guess about the confusing part of timer programming:
-Timer offers DST option, and Dusk-to-dawn capability +> you have to decide whether to use these options or choose 'manual' option where DST is ignored. Read where you programmed this step and make sure you chose manual or auto.
-You can set 7 programs per week, Program1, Program2, etc
-Start with Program1: first, select days of operation for that specific program ... for example MO (for monday) or WKD (for weekend)
-After setting days of operation, Program1 has to have an ON time.
-After setting ON time. Program 1 has to have OFF time.
-After setting OFF time, you press a button to save Program1 (sometimes this step requires you to push the on-off button or manual override)
-Next, you repeat the same steps for Program2
-The timer ignores conflicting programs > for example Program1 says ON at 7 and OFF at 8 and Program2 say the opposite, timer will ignore both programs.
3) Post photo of instructions on Flickr or Imgur
-Flatten instructions between pages of a book for a few days, and then scan instruction in file format (same format as you scan a photograph or have Office Depot scan instructions for you)
You can post the photo of your instructions on Flickr or Imgur
... and then we can go look at instructions and help sort out the confusion.
Oct 03, 2010 | Globe Electric Globe Indoor/Outdoor Lights...
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Timer on samsung digital camera?
Sure ... be sure to use a tripod or other device to place the camera for stability.
  • Set the MODE DIAL to your desired photo setting
  • Press the SELF-TIMER button on the button pad (looks like a clock/timer on the right button pad)
  • There are three settings
    • 10 SEC - 10 seconds will pass until the picture is taken
    • 2 SEC - 2 seconds until the picture is taken
    • Double self-timer - a picture will be taken after 10 seconds, and then after 2 seconds a second picture will be taken.
  • Press the SHUTTER button to begin the timer.
  • Jump in the shot! =)
Please rate FixYa! ThankYa!
Dec 15, 2007 | Cameras
Fuji FinePix S5000 Digital Camera Logo
43 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
