Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
I have fitted Kodak inks and it still says replace ink
    Novelist:
  • 136 Answers
there's a couple things you can try:
pull out the cartridges, and clean the contacts off with q-tip and water - also clean the contacts on the carraige. sometimes if it's not getting a clear signal, it can get confused about what it's reading.
Thanks,
Posted on Nov 19, 2009
SOURCE: not recognizing new ink cartridge
I had the same problem during setup. I tried the sharp rapping and four-letter words solution, but that didn't work for me. I called customer service and after a looooooong hold (apparently everyone in the universe is having problems), I talked to someone who transferred me to the "print head" part of tech support. During the conversation I had so much trouble understanding the guy that I said I wanted to take him off speaker phone so I could hear him better, and I accidentally cut off the call. Wouldn't it be nice if call center people were actually understandable in English.
Nevertheless, he did give me a couple of instructions before I lost the call, and after I did them things worked right. Here is what he said to do:
1. Remove the black and color cartridges.
2. Place finger in upper left hand corner of print head case and gently slide it down. That is when I lost the call, but as I did that the print head case easily slipped out.
I reinstalled it, put the cartridges back in, closed the printer and, voila, the calibration sequence started.
The tech guy took my number "in case we got disconnected," so he could call me back, but so far he didn't call back. Nevertheless, my printer's working. Next step is to hook it up to my computer.
Hope this helps someone.
Posted on Jan 03, 2008
Gerryl417
  • 5 Answers
SOURCE: Ink level will not reset when cartridge is replaced
If you take the cartridge to walgreens, etc... they can clear the chip. There is none for home use
give them a call !
Posted on May 10, 2009
Stevenslav
  • 65 Answers
SOURCE: dell P703 W printer and Kodak ink
Printer companies use different chemicals in their inks based on print head diameter and heat used to eject ink, using diffrent ink not supported for your printer can clog up the print head and make it useless.
Posted on May 21, 2009
  • 295 Answers
SOURCE: reset chip kodak esp 7 ink cartridge
Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges. The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
Posted on Sep 21, 2009
  • 295 Answers
SOURCE: I Filled Kodak ESP5 Ink Cartridge, but error remains
Try to reseat the cartridge 2-3 times. probably the carrtidge is defective. call kodak @ 1800 421 6699 and they will replace the cartridge for you free of cost.
Problem With Kodak Colour Ink Cartridge I bought a Kodak colour ink cartridge as it was saying replace colour, l installed it but it was still saying "replace colour" I thought maybe the cartridge cou
the kodak system uses a countdown system that assumes you use a certain amount of ink re sheet regegardless of how much ink you accutualy use, the counter system starts everyt ime you turn the printer on, so the only way to extend the life of the ink is not to turn the printer off netween use, which the domestic useres do not of course do what i did throw the printer away and get a new one not Kodak sh*t
Mar 28, 2013 | Kodak Esp 3250 Allinone Multifunction ( ...
Need KODAK #30 ink refill kit and chips or chip resetter
Kodak # 30 ink cartridge was made just for Kodak to help them get out of the red ink they are in. read the link below and see what they have done.
http://blog.atlanticinkjet.com/general-cartridges-posts/the-latest-printer-ink-from-kodak-inkjet-a-shift-from-the-cheap-ink-approach.html
Feb 12, 2012 | Office Equipment & Supplies
Just put in new ink and printer asking for new ink. Bought the printer just over 3 months ago and haven't even copied 75 copies. New ink installed and copied maybe 10 pages and computer asking for more...
I took out both inks, I then removed the tray they fit in. Turn it upside down and clean the contacts, use a soft cloth and dampen alittle. Clean all ink off bottom of ink tray. This solved my problem
Nov 20, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Check color ink always blinks and does not allow to do any job.
Make sure that you installed the correct ink. It is not enough for it to fit, the numbers on the cartridge have to match those on the cartridges you replaced. You may also have problems with off brand ink that claims to work. Use Kodak ink. Also, many of the Kodak have the ink jet nozzle on the printer, not the cartridge.You can try cleaning in and around the cartridge casing, especially on the copper areas, with an alcohol swab. Then run the cleaning utility on the printer 2 or 3 times.
Nov 09, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5300 will not accept the new ink cartridges
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
5100 ink error
Both printer ligh flash red yet both cartridges are new and full.
I have removed printer head and swiched of printer for 15min as suggested by Kodak but the red light still flash.
Please can you help.
Kind Regards - Patrick
Mar 03, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
37 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
