Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Simpletech 320 GB
I have the Blue Simpletech 320 Gb hard drive, i installed the button manager and the total media backup program on my MAC, when i use the backup program i select the files i want transfered and when i press the backup button it always says Not enough disc space- what? there's nothing in this big hard drive except for the drives and downloads allready preloaded on it, please help
  • Anonymous May 03, 2008
    I am trying to back up a file that is under 16mb on my new simple tech 160gm portable drive... I keep getting this message saying not enough hard drive space please reduce the project size or free up more space on the hard drive... I have simple portable as the backup destination.
    Why is this happening???  I am only trying to put some small files into this new empty hard drive.  This is one of the worst hard drives I've ever owned.  I can not bring it to another computer without installing software.  I bought it so that I could bring what I'm working at on school home and transfer that information easily... this device is not easy not simple and I hope I can still return it!
  • Anonymous Jan 18, 2009
    not seeing in my system
    windows and mac
How do you open it?
Posted on Mar 05, 2008
My advice to you is open it and unplug the one touch button.
Posted on Feb 09, 2008
Simpletech 250 GB External Harddrive won't backup 180GB . Says it is full.
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Jul 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I have uploaded everything on my Mac laptop hard drive to my SimpleTech external hard drive. I removed most of my music (in iTunes) and some other files to make room on my Mac. Now I'm having trouble...
You may need to tell iTunes where your iTunes media folder location is. You can do this in iTunes, go iTunes>Preferences>Advanced Tab>Change button, then navigate to where your iTunes media is and choose this as its location.
Feb 16, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Black
Try to go through disk management and see if it works?
Open control panel then select administrative tools then disk management. Then in left column click disk management.
If you locate it may be it must be initialise by the system or need to create partition by formatting.
You can also check all the cables , the power cables the adapter , try to change the Usb cable also..
ok
Good luck !!
Jan 22, 2010 | SimpleTech 320GB SimpleDrive External by...
I have SimpleTech drive that I used Storage Sync to back up C drive. Took drive to work and since all the files are 'bpa' cannot open them. I compare this to a simulation of what I bought the drive for -...
The BPA files are the backed up copies of your data. The simpletech utility backs up your files to compresse file ending in BPA. Any computer running the simpletech restore program can extract the data from these files.
You will simply need to install this software on a spare computer in order to test the backups. Frankly though I would just use windows backup to copy the files/folders you want to the drive raw as this can be read anywhere.
Hope this helps FixYa,
Chris
Sep 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech drive
Using this program http://www.ridgecrop.demon.co.uk/dow...at32format.zip
Its worked perfectly on my 300GB usb drive, my PS3 can see it just fine
Oh and it works on vista as thats what i did it on..
Aug 01, 2009 | SimpleTech 320GB SimpleDrive External by...
MISSING STORAGE SPACE
HARD DRIVE NEVER SHOWS TOTAL.ITS BECAUSE OF A CONFLICT CONCERNING WHAT SOME SAY IS A GB. ITS NORMAL AND YOUR DRIVE FINE.RELAX AND ENJOY.RICHARDM69
Dec 06, 2008 | SimpleTech 320GB SimpleDrive External by...
Simpletech 320 gb
It has to do with the way computers count. Computers count in binary where we count in decimal.
Hard drive makers list there drives capacities in the decimal format, where windows lists it in it's binary format.
Wikipedia has a good explanation.
Also, the drive may have some preinstalled software on it that could be taking up a bit of space (it's usually not much).
May 15, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleTech 320 gb. Code 10 Problem
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
314 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
