Question about Lexmark C760 Laser Printer
103 service ITU ERROR - Lexmark C760 Laser Printer
  • 320 Answers
Lexmark basically has said that if this error doesnt clear by powering off the machine and powering it back on again then it will need to have a service call. this error means there is a problem with the itu belt assembly.below is what they say. the steps were to pwoer it off and back on again using a grounded wall socket
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2
No:
Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
No: Print a test page. If the page prints, the printer is functioning correctly.
Posted on Nov 22, 2009
2 Suggested Answers
  • 32 Answers
SOURCE: 100 ITU error
Have you recently replaced the ITU? If it is saying ITU Maintenance, then the kit needs to be replaced. If you have already purchased and installed a kit, the reason this error is coming up is because the second transfer roll (small roller under the ITU) is not installed properly. Otherwise, you should purchase and install a new ITU maintenance kit.
Posted on Jul 24, 2009
Workcenter 7346error 103-310
That error signifies the following:
Hybrid WaterMark detection hardware unloaded is detected with SW option function being set to Valid. Detected prior to 103-311 detection.
Verify that the Secure Watermark kit is installed and configured correctly.
Aug 11, 2014 | Xerox Office Equipment & Supplies
Does compaq nx6310 have in built modem?
Hi!
Yes, it actually has a built-in modem, here is the specifications:
Max Transfer Rate 56 Kbps
Modem Fax / modem - MDC
Protocols & Specifications ITU V.21, Bell 212A, ITU V.22, ITU V.22bis, ITU V.29, ITU V.32, ITU V.32bis, ITU V.34, ITU V.17, ITU V.23, ITU V.27ter, ITU V.8bis, Bell 103J, ITU V.92, ITU T.30, ITU T.4, ITU V.250, ITU V.251, ITU V.80
Fax Compatibility G3
You can also check all hardware details about that laptop at: http://www.laptopdrivers.net/specs/hp_compaq_nx6310_laptop.htm
Hope this helps.
Apr 17, 2011 | HP Compaq nx6310 Notebook
100.01 Services ITU Error, Lexmark C782
From the Lemark Service manual
A 100.01 ITU error indicates that the printer did not detect the ITU belt home sensor. Before proceeding with this
service check, make sure that the Second Transfer Roll is correctly installed. After you reinstall the Second
Transfer Roll, check to see if a 100.01 ITU error is still displayed. If a 100.01 ITU error is still being displayed,
continue with this check.
The ITU has an optical sensor that watches for a piece of reflective tape on the inside of the image belt. This
tape is read every revolution of the belt. If a signal is not received from the belt sensor within a certain time
period, the printer posts an error due to the loss of signal. There are several causes for the loss of signal. First,
the belt has tracked too far to the front or rear of the printer. In this case, the belt is still turning, but the reflective
tape is no longer passing within view of the belt sensor. This is considered a belt tracking error and is initially
posted as a 100.02 ITU Error. The other causes of a signal loss could be a belt stall, meaning the belt is not
turning, or a true signal loss, which would be due to a bad sensor, broken cable, loose connection, or bad
system board. These other causes post as a 100.01 ITU Error.
To assist the printer in determining the cause of a signal loss, there is a buffer that records the belt position for
the last 50 revolutions. If the printer loses the belt signal, it refers to the buffer. If the buffer shows significant
mistracking before signal loss, it will post a 100.02 ITU Error. If the buffer shows that the belt has been tracking
in the center before signal loss, it posts a 100.01 ITU Error. Due to memory restrictions, the buffer is not saved
during POR. This means if a printer posts a 100.02 ITU Error, so the belt is tracked off, and the customer or
servicer turns off the printer to clear the error, when the printer starts up, it will still not see the belt signal and will
now post a 100.01 ITU Error because the buffer is empty. When servicing a printer for a 100.01 ITU Error, it is
important to view the error log. See "Display Log" on page 3-29. The error log can only be displayed at this
point. Do not try to print the log. Look for past occurrences of 100.01 ITU Errors preceded by a 100.02 ITU Error.
Apr 13, 2011 | Lexmark C772dn Laser Printer
Eror e00014 pada ir 5000, sudah dierror *28* tetapi tetap masih eror. motor pemanas tetap gak jalan gimana yaaaa? tolong dong solusinya...
bos tolong nih, kode error E00004-0010 pada mesin canon ir 6570, gimana solusinya. terimakasih sebelumnya
Mar 17, 2011 | Canon imageRUNNER 5000 Copier
STREAK ON ITU OF LEXMARK C782
The only thing that helps is replacing the ITU.
Jul 09, 2010 | Lexmark C782dn Laser Printer
DFM 562IS (DFM-562IS) Modem: SIR PLEASE SEND ME ITS ALL FEATURES.......
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
K56flex
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Computers & Internet
Error Code 23.05 ITU Missing
ITU is missing or defective. Replace the ITU and the problem should be solved.
Gerrit Jan
Nov 04, 2009 | Lexmark C780dn Printer
83 itu maintanece
You replace the ITU it has reached its end of life cycle.
Jan 22, 2009 | Lexmark C762 Laser Printer
Printer C760
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Aug 13, 2007 | Lexmark C760 Laser Printer
Lexmark C760 Laser Printer Logo
331 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
