Question about KitchenAid KSS42QM 42" Built-In Side-By-Side Refrigerator w/ 25.3 Cu. Ft. Capacity, In-Door-Ice Disp...
K.a.42 s by s freezer fan will not come on i
K.a.42 s by s freezer fan will not come on i removed and tested it . and it works but
when i removed it , ground wire was off and
there is a ground wire on top of ref. near comp. is also off will the fan run without
ground .also tested harness at fan conn. and its getting 47 volts whats up with that.
    President:
  • KitchenAid Master
  • 1,922 Answers
Yes the motor will run fine w/o the ground wire, it sounds as if the neutral connection from the motor is faulty somewhere and the 47 volts is a capacitive (GHOST) voltage you are reading, try this clip on wire from the voltmeter to the ground wire and then check for 120 volts on the harness wire with the other meter lead, when you find line voltage then you'll know it's a neutral problem because neutral and ground are at the same reference to ground at the main panel tie
Posted on Nov 19, 2009
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
I have a sub zero 361rfd. The freezer portion is no longer cooling, however the fan still runs. Also, The refrigerator is set to the coolest temperature but I suspect it's not sufficiently cold....
Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level
Hoping that this will help to solve the problem....
Aug 18, 2011 | Refrigerators
The freezer is working but the frig. is hot, when is the freezer fan supposed to come on ? How do I test it - I have a multi meter but do not know when it is supposed to be getting power.
How To Test the Evaporator Fan The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer.
Caution: Before testing the fan, unplug the refrigerator to avoid an electrical shock hazard.
The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver.
evapfan.jpg Remove any screws that secure the fan or fan housing so that you can access the fan's wiring. Typically two screws secure the mounting bracket in place (labeled "A" below). It may be easier to remove the entire rear panel if the mounting brackets screws are inaccessible.
Spin the fan blade, it should move smoothly and freely. If the movement is not smooth, the motor should be replaced.
Test the fan for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of zero ohms. If the fan does not pass this test, it should be replaced
Jun 08, 2011 | Haier Refrigerators
Kenmore 253. 9287413 Can't get the freezer to get cold enough. Freezer alarm keeps turning on and the temperature is only 25 degrees inside. Temperature alarm light stays on all the time. Quick freeze...
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
I hope this will help in solving the problem......
May 10, 2011 | Refrigerators
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezer not cold.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
My ge profile arctica fridge is reading about 42 degrees, but the freezer side is working fine . Its about 5 years old, a tech took a look at it and said the fans and fuses looked fine... any ideas?
u probably are starting to get an ice up behind the freezer compartment or your fan has stopped blowing the air into the freezer first thing is to make sure the fan is blowing the cold air into the fridge side if not then there is your problem if you do feel the fan blowing then you would have to carefully remove the rear panel and check in the areas that have willcall them holes tat go into your fridge if they have ice built up inside of them if they do have ice then you have a defrost problem and would have to be aqble to perfom a continuity test on the deforst thermostat and the defrost heater if both of these are fine the next thing that you would look at would be your defrost timer check for the air and the ice and if you stillhavent found the problem write back hope this helps
Jul 21, 2010 | GE Profile Arctica 25.4 Cubic Feet...
I have ice in the refrig compartment at the top and freezer fan is not working
if fan is not working it will ice up , most likely bad fan ,remove fan and test it and see if it runs out of frig , or have it tested might need to replace fan
Feb 03, 2009 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Evap fan not working
you must remove baqck panel from bottom of freezer compartment, there you can access fan and other freezer components, check for open defrost thermostat as well.
Mar 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
KitchenAid KSS42QM 42" Built-In Side-By-Side Refrigerator w/ 25.3 Cu. Ft. Capacity, In-Door-Ice Disp... Logo
80 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
