Question about Miele CVA610
Parts list and drawing for a miele CVA 620 coffie machine
  • 177 Answers
You would have to contact Miele spare parts for this information it is not readily available on the internet.
Posted on Aug 18, 2010
Miele cva 620
the heater block possibly has a hole in it, take it to a repair centre, it will need replacing, if you keep using it it will start to short power out and could damage the electronics inside
Apr 26, 2014 | Coffee Makers & Espresso Machines
Miele CVA 620 part 9161.391.xx0 where does it go ? Can I obtain instructions for setting up a new grinder ?
miele-cva-620-part-9161-391-xx0-go-nsr413nfwic5kgfniqnnhys0-3-1.jpgIt is the cover of ground coffee quantity. You loose it when you unscewed the first scew of coffee bean container base.
Jan 22, 2013 | Coffee Makers & Espresso Machines
Miele coffee machine cva 620 saying water system fault
Wow, I used a shop vac as someone else had posted. I realised that there are actually two valves where the water tank rests so I vaccuumed from the valve closest to me and a lot of water was sifoned out. Then my CVA620 coffee maker reset itself. Make sure you go through the coffee making process as the first coffee was not up to standard.
Apr 14, 2012 | Miele Coffee Makers & Espresso Machines
I have a Miele Coffee Machine (built-in) CVA 620-1. I got a message saying the brewing unit is blocked. I removed the waste unit, a procedure that has to be done before you can remove the brewing unit. ...
The brew unit has lose parts on left-hand-side, wiggle them up and down. Put the waste unit back, switch off the machine and then turn it on (pull the cord). It worked for me!!!
Sep 14, 2010 | Miele CVA615 Espresso Machine
No 'real' coffee taste or crema - despite following instructions
Set the machine for the finest coffee and the least water.
You should get a decent espresso.
For a regular cuppa, keep the settings the same and make either a medium coffee combined with a small coffee (jolt) or
make two small coffees.
I have this machine and the crema is nice at this setting.
Aug 01, 2010 | Miele CVA615 Espresso Machine
Display message - brewunit block - can not undo to start the machine Miele CVA 620 Build-in Automatic coffee machine
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
Jan 13, 2010 | Miele CVA615 Espresso Machine
I have a Miele CVA615. I think I should replace
Hello Phickok,
It sounds like the perculator may need to be replaced (The entire unit with the 'O' rings on it). As I recall the plunger is an integrated piece that cannot be replaced on the CVA-615/620 models but you may want to contact Miele technical services on this. These first generation coffee systems are very complecated to troubleshoot
Sep 05, 2009 | Miele CVA615 Espresso Machine
My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Jul 05, 2009 | Miele Coffee Makers & Espresso Machines
No program mode in Miele CVA620 espresso machine
my miele cva 620 coffee machine not working only the LED screen lit up and nothing else? any ideas.
Apr 10, 2009 | Miele CVA2650 Stainless Steel Espresso...
Miele CVA610 Logo
2,827 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
