Question about Gateway 830GM PC Desktop
I have a Gateway 830GM, I was wondering if it were possible to change the motherboard so I could put a newer CPU in it? I would like to buy a core 2 duo motherboard + CPU but I am not sure if I can do that without changing other things on the computer. I have upgraded the PSU within the last 2 years.
  • Gateway Master
  • 32,281 Answers
Desktop computer cases have standard mounting holes and screw stand offs.
There are a huge range of motherboards available, select well known brands, my favorite are Gigabyte, Intel and MSI.
Select a motherboard with the features you require. If you are into gaming, graphics/CAD then select a motherboard that does not have a built-in graphics chip, and then you can get a high end graphics card.
Most likely you need a CPU and RAM with your new motherboard.
You may also need a newer ATX2 power supply if not then check the total power requirements of the new system, it needs to be at least 10 to 15% over the total power requirements so you don't stress the switch mode power supply.
Posted on Nov 19, 2009
Testimonial: "Extremely fast and very knowledgeable. A million thanks."
Intel core 2 quad 3.0 ghz
aiden check out the computer dealers sites.
Apr 17, 2013 | Intel Computers & Internet
Need to find witch motherboard fits gateway computor M-6843
http://support.gateway.com/s/Mobile/2008/Avalon/1015608R/1015608Rnv.shtml
Click on Components in the list.
Scroll down to -
Motherboard:
4006229R - Motherboard GM965 Chipset Intel Video W/10/100LAN No HDMI (FRU)
Click on the above.
Main View
Specifications
http://www.buy.com/prod/gateway-4006229r-gateway-m-6750-m-6755-m-6834-m-6823a-m-6846/209257968.html
http://www.codemicro.com/store/product/Gateway-4006229R-New.php
http://www.ebay.com/itm/Gateway-M-6750-Motherboard-31SA1MB0030-DA0SA1MB6E0-IS-read-carefully-/261119779234?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D3052480971542613513%26pid%3D100011%26prg%3D1005%26rk%3D2%26sd%3D270875445041%26
Just from some quick searches. Note that -
31SA1MB0030 is also another reference number.
May I ask what the problem is?
Power problem?
Do you have decent soldering/un-soldering skills?
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Computers & Internet
I have an 830GM and am suspicious of a hard drive crash or a motherboard failure and was wondering how to diagnose?
try replacing or swapping the hard drive with another machine and see if it happens again and on which machine if both machine's crash both MB and HD could be bad, If your machine with different HD works fine then it most likely was the HD If not then the MB might be at fault
Jan 24, 2011 | Gateway 830GM PC Desktop
I have a pentium 4 cpu on asus p5gpl can i change the cpu into duo cure for example does the motherboadr support higher cpu?
I have had a look at the Asus website and i doesn't appear to support dual core or core2duo.
Sorry. If it is about 5 years old, then if you can afford it , buy yourself a newer upto date MB, CPU and Memory.
Sorry I can't help any further.
Jan 19, 2010 | ASUS P5GPL Motherboard
Sir can i change my processor to dual core using this asus p5v800-mx?
Dear sir,
Deffinately This Mother Board supports Dual core 2ghz-2.8Ghz And Pentium D 3GhzProcessors.You can Upgrade your PC.
P5V800MX motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Enjoy the extraordinary CPU power from the latest dual-core CPU.
Aug 04, 2009 | ASUS P5V800-MX Motherboard
Need new motherboard for Gateway 830GM
Looks like you have a p4 478 socket with ddr memory bad luck they only make 478 boards with ddr2 memory now. And when ever the power supply is as old as the motherboard it should be replaced to. Here's the specs I found on your computer http://www.shopping.com/xPF-Gateway-830GM. You could always try your luck on ebay good luck.
Jul 11, 2009 | Gateway 830GM PC Desktop
Motherboard wiring
cba3c97.jpgthis is the diagram for 103390 Intel (Augsburg) 915G
Jan 06, 2009 | Gateway 830GM PC Desktop
Uppgrade to a faster processor?
Hi
Pentuim D is a processor that has 2 x cpu in one and a core 2 duo has 2 cpu's plus 1 smart core bigger cache
you can only upgrade to a E2140 or E2180 processor on that motherboard
OR replace the board with a newer type
If you want to work the actual speed for the processor of a dual core take the speed for example dual core 1.8 x 2.1 =3.78 GHz
Core 2 Duo  1.8 x 2.4 = 4.32 GHz
Sep 23, 2008 | Computers & Internet
Gateway 830GM PC Desktop Logo
150 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
