Question about Acer Aspire One Netbook 8.9" Notebook
I have just plugged my acer netbook in for the first time left it for 15 mins and it will not grt past the windows xp screen
  • 56 Answers
May be the window have problem then you need to get another xp window . or the window is updating.
Posted on Nov 19, 2009
How do i reboot my acer one happy n55 netbook?
Please give us more details
What is the Operating system ( windows ) you use ( xp, Vista, Seven )?
Which password ?
Regards
Nov 14, 2011 | Computers & Internet
I pressed f10 lots of times and my internet just stopped working ,i wanto reset my klaptop to factory settings please can u help
All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows xp factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
1. have the netbook connected to its AC adapter which is plugged into AC power line
2. power on the netbook and watch the screen as it starts up
3. when the acer logo is showing, hold down the Alt key and press F10 repeatedly
4. until screen indicates Acer eRecovery is loading
5. once eRecovery is loaded, follow the directions given on the screen
May 08, 2011 | Acer Aspire One PC Notebook
I have a acer netbook.when i press standby or close the lid then it become go to sleep mode but problem is creating when press enter button then i cannot start any program or it go to hang position. my...
If your windows xp is not genuine, it likely has been corrupted. This would also explain why you cannot start any program. All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows xp factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
May 08, 2011 | Acer Aspire 5315 Notebook
Hi, my acer aspire one netbook can't open XP and it says netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can...
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Apr 10, 2011 | Acer Computers & Internet
I have an Acer One netbook and tried to connect it to a projector but the normal looking lead from the projector did not seem to fit. The lead has those two wee screws at the side, and no place for them...
The Acer One netbook has a mini-VGA port on its left side. Page 10 of Acer's QuickGuide shows the port as item 3 External display (VGA) port. But unfortunately, the description shown for it is incorrect.
From your description, your projector's lead likely has a mini-VGA connector on the end as pictured. The connector can simply be plugged into the mini-VGA port but there are no holes beside the port for screws so it would just be a friction fit which should be sufficiently secure for most puposes. The connector and port are mini-DB 15 male and female respectively and can only fit one-way. The port has the wide side of the D on top so you would have to turn the pictured connector over to be able to plug it into the port. Windows XP should be able to detect the projector via plug-and-play installing any display drivers if required. Page 8 of Acer's UserGuide describes Hotkey + Display toggle which switches display output between the display screen, external monitor (if connected) and both. Pressing + with the projector plugged in will bring up a window in the middle of the screen allowing the selection of internal display, external display, both, or a 800x600 VGA projector. If the display is on the projector, unplugging the cable should automatically revert display back to the internal screen. For VGA see http://en.wikipedia.org/wiki/VGA_connector splines.jpg
Jan 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
HOW DO I USE MY WEBCAM ON MY ACER ASPIRE ONE NETBOOK?
Certain models have are shipped with Acer Crystal Eye Webcam software which enables webcam at boot. I do nto know if it is installed in your netbook.
To test the webcam running Windows XP, follow the steps below:
  1. Go to Start, All Programs, then Windows Movie Maker.
  2. On the left side, click the link for Capture from video device.
  3. Select Next throughout the set up, making any file name changes or setting changes if desired.
  4. On the Capture Video screen, click on the Start Capture button
  5. You will see the video on the right with a time count up
  6. When you are done click the Finish button
  7. Click the play button on the video clip, or drag the clip to the Storyboard below.
If your webcam is not detected or if you are running Windows Vista click the link below.
The wesite has live chat support in case you get stuck
http://netbooks-us.custhelp.com/app/answers/detail/a_id/86/related/1/kw/webcam/r_id/166
Jan 13, 2010 | Acer Aspire One AOD150-1920 Netbook
If i leave it for 15 min it automatically grt shutdown?
go to your control panel (from teh start menu, or round blue icon in the bottom left corner) and look for power options. you can customize power settings in there, most laptops are set to go into suspend mode after sitting for a while to save power. you can set the amount of time that it waits before suspending itself, when its plugged in you can set it to stay on all the time. there are seperate settings for when it is on battery as well.
Dec 09, 2009 | Acer Aspire 4530-5889 Notebook PC
NEW ACER ONE NETBOOK WILL NOT BOOT UP
Try Safe Mode.Disconnect every device (Mouse also)
Hit F8 at very beginning until you get a list of options select Safe mode and check if Windows starts.
then try step by step confirmation option.
say yes to every request until freeze: last driver you accepted to load is the culprit.
Remove it in Safe mode using Start/Run/Msconfig
Dec 26, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
