Question about NetGear WGR614 Wireless Router
Comcast technician misspelled the name of my wireless connection. how can i fix it
  • Chris Hingee
    Chris Hingee May 11, 2010
    Do you mean the SSID? You should also check if he secured your wireless from unauthorized access. To connect to your wireless router, it needs the router?s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router?s wireless settings. Then the laptops and desktop computers can communicate with your wireless router. To set-up and secure the wireless router from unauthorized access, follow these steps: - 1. Connect the wireless router to your computer with a LAN cable. 2. Start your browser and enter the router's configuration URL IP address. 3. Enter the router setup, login and password 4. Change the admin password 5. Go to the wireless settings and change the default SSID and turn off SSID broadcast. 6. Setup encryption key the strongest is WPA2 (if not then WPA). 7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router. 8. Record the settings you have made and keep it in a safe place and Save the settings. 9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router. 10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
  • 2,260 Answers
You will need to access the router set up.
Do you have any computer connected to the router ?
If not then you will need to connect the computer to the router with the Ethernet cable.
Then access the router set up. Under wireless settings you will be able to change the name or also called as SSID.
Click Here to know how to access the router set up
Posted on Nov 19, 2009
I am trying to connect my tablet to xfinty
You have to connect the tablet to your Arris 862 gateway "comcast modem" the key to your wireless is on the bottom of the modem on white sticker. The key is case sensitive most generally all in caps. Your network name is as well on the sticker should be HOME- and a 4 digit number. To get the tablet to connect you need go into "settings" on the tablet and then tap "wireless or may say WIFI", Find the comcast modem/router name "the Home- whatever number it is click it then it should prompt you to type in the network key.
Mar 22, 2015 | Internet Computers & Internet
Dell Inspiron5150.
Does your WiFi work at another location like Dun-kin Doug-nuts?If so then you have an issue with you router.
Call Comcast or Google search on that model.
Feb 08, 2013 | Dell Inspiron Computers & Internet
Netgear wirless - installed on toshiba satellite a45 - S151 will not connect to internet router = comcast - linksys also causes conflict with connection of other wireless computer
Presumably, you have configured your wireless router:
* SSID (your "network name")
* encryption-level ('WPA' or higher security)
* password for your network
With that information, any wireless device (iPod Touch, iPhone, NetGear wireless adapter) should be able to connect to your wireless router.
Exactly what error-message are you getting?
Feb 21, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
I have a Motorola Surfboard SBG900 wireless router and my provider is comcast. Comcast came out and changed some wiring and connections but i continue to loose connection, every couple of minutes. What...
i had the same problem. it turned out the power to the modem was shorting just enough to throw me off and have comcast resetting the ip address and connection. i fixed it by getting a new power supply and plugging it in to a really good strip bar. hope this helps
May 28, 2010 | Arris SURFboard SBG900 Wireless Router...
How do I hook d link up to my comcast router so that I can use it with my laptop?
Well, you are trying to connect a router to a router, that can be difficult. Is there anyway you can exchange the Dlink router for a Wireless Access Point (AP)? If you can, you just connect the AP to the 4-port network side of the comcast router, configure the wifi settings (security, etc), and you're good to go.
If you can't exchange it, then your best bet is to connect the 4-port (or internal) side of the dlink router to the 4-port side of the comcast router. Then the dlink will be seen by the comcast router as another internal connection, and you can set the wifi settings of the dlink at that point. If you connect the dlink to the comcast router via the External port on the dlink, then you are creating two separate IP subnets, a needless complex setup.
Nov 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
When I recieve a phone call through my comcast phone, it disconnects my wireless on my Belkin
I assume you are using a Comcast modem that you plug your phone into.
Does a wired connection to your router work when you get a phone call or just wireless the wireless is cutting out? If both cut out then this problem is on Comcast's side. You can call them using 1-800-COMCAST to have them fix the issue.
If the wired connection works but wireless does not, I would guess you are using a cordless phone that is running on the same frequency your wireless router is. If this is the case, you can change your router's configurations to operate on a different frequency. This can be done by opening up your internet browser and entering the router's configuration menus by using a URL(address) of 192.168.1.1 (possibly 192.168.0.1). Once you are in the configurations, look for options for wireless frequency and change them to something else.
If this does not work, I would suggest calling Comcast because the problem more than likely resides on their end.
Oct 17, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do we get a D link air plus G-630 to connect to a linksys wireless router? Comcast cable modem, linksys router, Dell inspiron 1100 running XP.
Install the driver of the Dlink Airplus and adapter to the computer, after that connect to the wireless network to the name was made to router.
Note: When connecting to the wireless network find the exact wireless network name of your router.
Mar 10, 2009 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
Connection problems with secondary computer
hi
the key code is the security code or the password that is enabled in the router,are you trying to connect to you own comcast network or to someone elses??
if you are conecting to your own comcast network then you need to log into the computer which can go online using you comcast box,once you are in that computer you need to go ahead and click on start,run in the box type in cmd and hit enter,it shud open a black box for you in this black box go ahead and check the default gateway an example of default gateway wud be like this no 192.168.1.1,make a note of the default gateway and open an internet explorer page now type the default gateway in the address box without http,it shud open the router page for you from comcast,it will tell you to put in the user name and password,the default for comcast is username is comcast and password is 1234 incase you cannot login you can contact comcast so that they can reset the password for you,once you are in this page you will see the wireless setting click on it and there you will see something wghich says wireless security or wep key or authentication key that is the key code..u can now use this key code to connect to the network....
if you are trying to conect to someone elses network thent he person who has setup the wireles comcast network will be able to give you the network key...
vedhick
Jan 21, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
G wireless router
You should disable the WAN miniport pppoe. SSID is the wireless network name or the signal's name coming from your wireless router.
After disabling the wan miniport, Right-click on Wireless Network Connection > View Available Wireless Network. If you see several networks listed, highlight your wireless network and click Connect. That should do it.
Sep 28, 2008 | Linksys Wireless-G WRT54G Router
Setting up a wireless router
Here are some pretty good instructions from Microsoft:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Aug 12, 2008 | Dell Inspiron 8600 Notebook
NetGear WGR614 Wireless Router Logo
64 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
