I have a goodmans dvd player and a samsung flat screen tv.when i try to play a dvd the picture is fine but no sound.
    Scholar:
  • 53 Answers
What type of cable are you using to connect the TV & DVD together?
You may also need to connect the 2 RCA(Phono) plugs for Left & Right Channel sound if you have used an S-VHS cable for the video link-up.
Posted on Nov 19, 2009
Testimonial: "andy.thanks for that.i'll give it a go."
I have sound but no picture since this morning...I can play DVD's fine through the TV.HELP!!
You are experiencing a bad video processor, that means you will have sound, and if you are using the rca inputs, can even use a dvd player to view a movie, but the video processor in the actual tv is bad,
Mar 04, 2011 | Samsung PS42A410 42 in. HD-Ready Plasma TV
No sound or picture from dvd
And you have selected the HDMI2 input in the TV menu? If yes, try the dvd on another TV, if you have one. Also try reversing the HDMI cable.
Jul 01, 2010 | Bush DVD2038 DVD Player
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
May 30, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Tv and dvd remote controls interfere with each other
found out that signals from both remotes were on same waveband
moved dvd player tp differnet tv in diferent room and bought new dvd player to couple with LG flat screen
Not a technical solution bit did the trick
Ray
Dec 08, 2008 | Televison & Video
Goodmans gtvl2628hdf no picture at all
yes change your tv backlight inverter
Oct 11, 2008 | Goodmans W280NS Television
Goodmans 17" LCD TV always sound, intermitent picture.
Give little spray of W-40 contact cleaner in Scart, seems has lil dust / rust.
Aug 02, 2008 | Goodmans Televison & Video
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
