I have an emachine T2484 that will not power on. I replaced the power supply hoping that would fix it, no luck. I unhooked the power switch from the motherboard and linked the two pins on the motherboard briefly together with a screwdriver to see if my switch was bad, it did not start. I replaced the motherboard, no luck. I double checked the power supply on another system and it works fine. I replaced the power cord, no luck. Now I am clueless as to what to do next. Any suggestions?
Try to start it without any memory in it (RAM), if it beeps then you have bad RAM. If you have more than 1 piece of RAM then try one at a time and see if it will boot. If it doesn't beep and still doesn't turn on your CPU is probably the culprit since you have a new motherboard and power supply. I would also try unplugging everything that is unnecessary like the CD-ROM, Hard drive, sound card, etc..
