HP Pavilion dv6000... will not boot nor does it load bios or setup options. screen displays F2 and Esc button options yet does nothing when eaither is selected. started having trouble with dvd tracking (picture kept freezing) I tried to reboot and haven't been able to since
  • 358 Answers
This is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again.
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself), and try to clean, or better still replace your processor fan.
If you cant do it by yourself, you can easily get a technician to do it for you.
Also, remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one. if the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
I have actually had the same case before, and after doing what I've just told you, it stopped behaving like that.
And you are also still very lucky, because after a while, if the case worsens, the system will not just get stuck, but it will power-off automatically.
Then always make sure that your laptop is in a well ventilated, cool environment and that the environment is free from dusts.
Kindly let me known how it goes after you've tried this.
Hope this helps you out.
Posted on Nov 19, 2009
    Champion:
  • 206 Answers
Your MB is dead
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
Reset bios
  • Restart the system. Click on "Start," "Turn off Computer" and "Restart."
  • At the Dell loading screen Tap "F2" to enter the BIOS. "Entering Setup" will appear. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
  • Once loaded, depending on BIOS version and type, you can reset the defaults by using "F9" key to Load Defaults, the "Load defaults" button on screen, or the "Alt" + "F" key combination to load factory defaults.
  • Press "Esc" on your keyboard and select save and exit.
  • Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your system to restart for the BIOS settings to reset.
Aug 30, 2013 | Dell Inspiron Computers & Internet
Booting problem
Restart your computer
have a close look at the screen it will be quick you will see which key to press to enter bios
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
others you might try
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Sep 27, 2012 | Sun Blade 2500 PC Desktop
Dv6000 will not startup ,Black screen , hd isnit being accessed
When you first turn the laptop on is there a HP splash screen? Can you enter the BIOS (normally by tapping F2 or Del key). If so then it would seem the BIOS updated OK. If when you turn it on there is nothing the BIOS flash probably went wrong and the machine will need a new BIOS flash chip installed.
If you can access BIOS then it may be a simple problem that the new BIOS reverted to default values. The most common issue would be the boot mode of the HDD. Look through the BIOS menus and there should be an option for boot which will say AHCI/IDE/Compatibility. Try changing it to another option, save and exit BIOS and see if that helps. Try this for each option.
Alternatively tap F8 continuously when you turn the laptop on and see if the advanced boot menu appears, if it does try selecting Safe mode with networking.
Finally to test if the HDD is actually working, try downloading Hiren's BootCD and boot to it. Then run some HDD diagnostics to see if the HDD is operating correctly.
Hope this helps,
www.PuterCare.com
Jul 07, 2010 | HP Pavilion dv6000z Notebook
Pavilion EZ4125 will not boot past the HP boot seletion screen.
Did it give you any blue screen error. Did you try booting from the CD. Its definitely something to do with the OS. Load the CD and run the setup and try to repair the OS.
Feb 12, 2009 | HP Pavilion ze4125 Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
Unable to get into BIOS SETUP
hi there,
On most systems, the key or key combination to press to enter the BIOS program is displayed on the screen when the system boots up, at the time when the BIOS is ready to enter Setup.
take a look at some default keys:-
  • {Delete} (modern Award and AMI BIOSes)
  • {F2} (modern Phoenix BIOSes)
  • {Ctrl}+{Alt}+{Esc}
  • {Ctrl}+{Esc}
  • {Alt}+{Esc}
  • {Ctrl}+{Alt}+{S}
  • {Insert}
  • {F1}
Apr 10, 2008 | Toshiba Satellite 5005-S504 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
393 people viewed this question
David Payne
David Payne
