Should it burn
I just purchased a samsung dvd-r 120 recorder. I was just wondering should it still burn a disc if its not hooked up to a tv?
thank you
  • ruchsie Mar 21, 2009
    I have an IBM Think Pad and have burned DVD's to DVD+R as well as DVD-R and my DVD players won't read either of them.
    Scholar:
  • 47 Answers
  1. DVD-RW reads and burn DVDs and CDs with or without a tv connections (computer accessory)
  2. DVD-R if its is a dvd player it should be able to read DVD and record dvds with tv connection (this is not a computer accessory but a tv accessory)
  3. DVD-ROM can only read and can not write on DVDs
Posted on Mar 25, 2008
I have a Sony SLV-SE 710B VCR and a Sony Bravia HD TV I now wish to record my videos (about a 100) onto DVD. What Sony DVD recorder will take the output from this VCR and put it onto disc or do I have to...
You need to buy Sony DVD Recorder and hook Sony VCR to that dvd recorder and burn DVD directly. You can also watch VCR tape movie on TV via dvd recorder while its being burn on dvd.
Click Sony Style to select DVD recorder.
May 11, 2009 | Televison & Video
Have a samsung Samsung LE26A456C and a toshiba dvd recorder. Have set up telly fine, set up video to play fine but cannot record
What is it that you are trying to record? If you are trying to record a DVD you have purchased onto a DVD-R, you will almost always run into a problem because most purchased DVDs have copyright codes burned into them, making them unrecordable. Most VHS tapes have these copyright protection codes in them as wel. If you are trying to record a television show, and are unable to do so, make sure that the DVD that you are using is compatible with your burner. If your burner is set up to record only DVD-R, then you must use only the DVD-R discs. If your burner is set up to record only DVD+R, then you must use only the DVD+R discs. Some burners will record both the DVD-R and DVD+R. If you have the right discs for your burner, make sure that the discs are correctly formatted to be recorded. Also, make sure that if you are recording from a cable box or other input that you have the correct unput channel selected on the burner. If these suggestions don't work, then it could be the brand of DVD that you have purchased (i.e. Sony,Maxell,TDK,Fuji,etc.). Check your manual for acceptable brands. I hope this helps you out. Let me know if I can be of further assistance.
Sep 08, 2008 | Samsung Televison & Video
Samsung SHW08A DVD±RW doesn't burn dvd+r
Its because you need a firmware update. The media you are currently using isn't recognized. I stumbled in here with the same problem. I haven't been able to find an update, so I will probably have to try a different brand of disc myself. The burner worked fine until I tried using a new pack of Verbatim discs.
May 21, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
Does not recognize a blank DVD
I bought DVD-R 1-16xspeed made by TDK which work fine.... it seems to be a bit of a mine field of discs available but I do remember these were recommended by Samsung via a leaflet in the box.
Apr 03, 2008 | Samsung DVDR120 DVD Recorder
are you putting in the right type of disc? dvd -r or dvd +r or dvd rw?
which type does the player take.
Feb 19, 2008 | Samsung DVD-HR720 DVD Recorder
Not recording a full film
1. Insert disc.
2. Press "DVD" button on remote.
3. Press "REC MODE/REC SPEED" button.
4. Keep pressing until desired recording speed.
I believe your problem is that the movie exceeds the 120 minute limit on the target disc at the default recording speed (SP). Try LP instead.
Nov 18, 2007 | Sharp DV-RW340U DVD Recorder/VCR
Transferring to DVD?
Maybe when you play the 8mm tape on the TV and have DVD/TV recorder hook up to the TV.
Oct 23, 2007 | Sharp Viewcam VL-A111U Camcorder
Samsung dvdr-120
try checking on the recording mode of the DVD. V recording mode produces more compatible DVD disc. Stay away from VR mode. You may refer to your manual.
Jul 26, 2007 | Samsung DVDR120 DVD Recorder
Computers & Internet Logo
187 people viewed this question
Alun Cox
David Payne
David Payne
