Question about Shure Audio Players & Recorders
I think the connections in the mic are loose or its broken. how can i get it fixed & how much will it cost.
    Scholar:
  • 53 Answers
A common fault with all corded/cable microphones is that one of the wires inside the cable breaks.
- I am assuming you are talking about a cabled mic?
It's possible to repair the cable if you have a soldering iron. This is the cheapest way to fix your problem.
If you don't have one, suggest you buy a new cable from your local Shure stockist.
The other major fault that occurs with mic's is that they are dropped - and that will show the same symptoms as you have descibed above if it has been dropped a few times - especially onto hard surfaces or floors!
The cable will only cost a few £'s or $'s, should be less than 10.
Posted on Nov 19, 2009
Can u connect a microphone to htr5740 receiver?
only if it has an input for it on the front. check specs from your manual.
there can be another way but it will cost you. a preamp mic plug into one of you inputs via rca connection
Apr 14, 2014 | Yamaha HTR-5740 Receiver
My tx rx light comes on when i key mic on my connex 4300hp ,,why
Check the mic wires inside the connecter, there might be a loose or broken wire that is making an intermittent connection.
Dec 28, 2013 | Cobra 29 LTD CB Radio
Radio squeals when mic is keyed up and truck is not running. Why might this be
Check the SWR's and also Check that you have at least 10 amps or more on the power wires that you are connected to. if possible run + - wire from battery to radio and see if it squeals , 10 ga wire should work, if just a plain 40ch radio. if an export with more than 60watts you would need more amps. ...
when the vehicle is running it may be getting enough amps, but when it is off. there may be a loose connection or small wires and not enough amps.
Squeal problems
low amp draw - small wire.
High swr's
loud talk back
shorted mic cable wires/broken wires
loose grounds
Feb 27, 2011 | Radio Communications
I have a two yr. old 55sh series 2 that just quit working. Looking inside the on/off switch cover, there are no loose wires. What to do next?
If you do not have experience in repairing these mics, you should probably have a pro audio technician do the work. The problem is an open circuit in microphone's internal wiring; either the mic cartridge is dead, or one or more of the fine wires connecting it to the microphone output connector are disconnected. Sometimes the fault is caused by a bad solder connection, or a faulty switch. As I mentioned, unless you have experience with these items, you can permanently damage a potentially salvageable mic. A goos tech should be able to identify the problem in a few minutes, and if the mic is repairable, it should be a cheap fix. Worst case scenario, a dead cartridge replacement may cost half the price of a new mic. But then, it's essentially a new mic.
Oct 06, 2010 | Shure 55SH Series II Professional...
I have one nokia1110 mobile phone. When i make or receive a call i can hear the voice of the person speaking but no one can hear my voice . need a solution
open pcb & select multi meter at ohmic value
check connectivity on mic pad at pcb if shows anythink connectivity just replace mic if does not shows anythink when you checked connectivity find wich contact are brokened
Method;how find wich pad are broken
place one probe of multi meter on pcb ground & check both pad of mic on pcb when does not shows connectivity on any pad of mic remember it after that arrenge other same type pcb & place any probe on mic pad that you identified & check connectivity at near about when shows on multi meter full conductivity & remember it now resold jumper between mic pad & that part that you searches in your foulty circuit board
Jul 09, 2010 | Nokia 1110 Cellular Phone
I have a scrolling problem. I think gear wheel is broken. What can I do to fix it? Is it possible to take gear wheel from the other mouse (I have old optical A4Tech mouse with PS/2 port)
You may want to open the mouse and see if there is any loose connections, with low cost mice sometimes it is easier to pay for a replacement but look for a loose connection first.
Nov 03, 2009 | A4tech X-750BF Mouse
Computer will not turn on even though it is plugged into the outlet. Why? How can I fix this problem?
Are there any symptoms other than failure to turn on? Do you hear the computer 'trying' to do anything when you hit the power button?
If it simply does not turn on, and you've checked to ensure the outlet is still good to go, then it could only be one of two things that i can think of off-hand:
1. Power Supply is dead. If you have another desktop computer that you can borrow from, yank the power supply out of it, cross your fingers that they have the same plug, hook it up and try to turn on again. If it still fails to turn on then the good news is your power supply is most likely good, but your...
2. Connection between the power button and the motherboard is faulty/broken/loose/etc. In the front of your PC, usually paired with a USB slot or two, and mic/headphone jack, is a power button connected to a small board connected by a thin wire to the motherboard. This is like a remote-control for power button and such. If the wires come disconnected or loose, the power button simply won't say 'turn on' and you'll experience this problem.
Fortunately, a new power supply runs about $60 and a fixing a loose wire costs about 5 minutes. So this is not catastrophic. There are other things that could cause this such as catastrophic motherboard damage (like half of it missing, perhaps) but if something happened to the computer to cause something like that, you probably wouldn't be posting here as it wouldn't be such a mystery :P
Jul 14, 2009 | Dell Inspiron 2200 Notebook
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
Galaxy 77hml
88, hi- the problem your describing depends on whether the red keyup light stays on while it's breaking up. I'll give you some possibilities to check as all of these could cause what your describing.
1- A broken audio wire in the mic cord.
2- Dirty mic switch.
3- The mic jack starting to come loose/or has rotated.
4- Circuit board ground screws starting to come loose.
5- Make sure all coax and jumpers are screwed on tight.
Thats about all I can think of right now, one of these is causing your problem.
Hope this helps you out, let us know,, Mechanic
Feb 05, 2008 | Radio Communications
Mic is broken
There is no pratical way for you to get your mic fixxed.
Jan 09, 2008 | Nintendo DS Lite Console
525 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
