Water is leaking from under the passanger dash board when i turn on the air con
    Problem Solver:
  • 11 Answers
The drain is plugged up, you need to look up the location of the drain for your vehicle
Posted on Nov 20, 2009
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
I have water under the passanger side seat that goes back to the passanger side back seat. What is this from?
Well if it leaks after a heavy rain, then suspect your windshield seal is simply bad and needs resealed.if it is anytime, then it sounds like you have either a heater core leak or a hose to the core.All that is contained under the dash on the passenger side.You will need to take off the plastic covers under the dash on that side then get up under the dash with a flashlight and look while the car is running.Let it get hot and turn the heat on also then just look for the leak.if it is really wet you wont have to wait long with the car running and the heat one to see the leak.
Aug 17, 2011 | 2005 Chrysler Sebring Conv
Water in the footwell????
air con evaporator drain pipe blocked or missing. condensation forms on evaporator and and must be ablr to drain out under vehicle. if drain blocked water will build up and leak into foot well. if missing water will drain directly into foot well.
May 20, 2010 | 1999 Volkswagen Passat
When air con on in my car water leaking down the front passanger side making very smelly carpet any way of fixing problem someone said drain need unblocking where is the drain
The drain is supposed to come out under the car, passenger side, ahead of the dashboard area. If yours is clogged, that's where you need to look once you're under the car. You should see a tube pointing forward or down, sticking through the firewall - that's it.
Nov 09, 2009 | Ford Futura Cars & Trucks
Water in the passenger floor board of my 2005 chevy cobalt
check your heater coil under the dash on passanger side for leak at joint areas. it could be condensation from the AC condencer dripping down the line that goes into the firewall, if so seal that area with a good sylicone.
Jul 23, 2009 | 2006 Chevrolet Cobalt
While running air conditioner, water began leaking from under dash on both sides of my 99 Nissan Frontier.
check the soft rubber drain tube inside the engine compartment it hangs down between firewall and engine, squeeze it to let the water out probably cloged. if cloged it backs up water into the passanger compartment and leaks inside car
May 02, 2009 | Nissan Frontier Cars & Trucks
Water leak inside car
Try check the AC water outlet hose there must be a leak from there.
Apr 30, 2009 | Mazda 626 Cars & Trucks
PASSANGER SIDE CARPET FILLED WITH WATER. WATER LEAK UNDER DASHBOARD
I've had this happen with several of my cars and what it inevitably turned out to be was a clog in the evaporator drainage hose. The moisture that condenses in your evaporator casing should drain out through a hose that leads out under your car but if the hose gets clogged that water backs up and ends up on the carpet inside your car. Sometimes its a bit of a hassle to get to but with a bit of work you can usually use a bit of wire or a pipe cleaner to clear it out. If you can crawl under your car, its also possible and sometimes easier to get at it from the there.
Aug 09, 2008 | 2007 Nissan Xterra Off Road
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
