Question about Samsung AW0603B Air Conditioner
I have three samsung window acs in my house, after
I have three samsung window air conditioners in my house, after every 4 to 6 months im spending round about Rs1000 to Rs8000 to repair them.
    Problem Solver:
  • 16 Answers
But in what are you paying so much , what are the cause and reason y ur spending so much .
Posted on Mar 19, 2010
Can a pro recommend a comperable replacement wall AC only-no heat?
Most air conditioners now are reverse cycle, which means that they can heat as well as cool. Cooling only units were popular many years ago due to the price difference for a reverse cycle. Today, the cost of manufacturing has dropped and it has resulted in cooling only units being virtually finished. I would suggest you get a local air con sales company to come to your house to measure up properly and determine what would be best. There are a lot of factors in installing air conditioning. IE/ The size of the house, the area it will be required to heat / cool, the amount of windows, types of walls, roof etc (Heat loading on the house) Roof and wall insulation etc etc.
Apr 09, 2014 | Heating & Cooling
Our bedroom Samsung AC died last night-really need it
Samsung AC died, really need it.
If the air conditioner blew a fuse or a breaker was tripped in the house, then reset the breaker or replace the fuse.
If the air conditioner fan works, and it's blowing hot air, then the freon level may be low in the air conditioner's piping system.
If the air conditioner is less than 30 days old or within the warranty period, take it back where you bought it for a replacement.
If it needs recharged, contact an a/c repair place that can recharge it.
Actually, new air conditioners cost around $100 which is very reasonable considering how it affects comfort and safety in the room it is used.
These are a few ideas that I would think about if I were in the same shoes as yours.
Good luck fixing it.
Jul 08, 2010 | Samsung Heating & Cooling
Why does my airconditioner leak
If this is a window ac then you need the back of the ac lower than the front, so the water can drain to the back.
Aug 18, 2009 | GE AZ28E15DAB Thru-Wall/Window Air...
I have three window ACs in my entire mobile home(double wide). One at the back of the house, one in the middle and one in the front. Each one is plugged into its own outlet. If I try to run more than one...
Susan; # A/C units in a mobile hme is a little much to much. I'm surprised it hasn't burned down. Upping yor circuit breaker would cause an extreme fire hazard.
Jul 10, 2009 | Gibson Thru-Wall/Window Air Conditioner
Air conditioner cant keep up and just keeps running!
IF IT WORKED BEFORE THEN IT COULD BE A CLOGED AIR FILTER. OR CHECK FOR CLOSED VENTS. WINDOWS OR DOORS NOT AIR TIGHT .
THEN IT MAY NEED TO BE CHARGED WITH FREON.
Jul 10, 2009 | Ruud Matching Split Air Conditioner
Ac fedders portable
Im not sure I understand the problem. Your AC runs about 4 minutes then the compressor stops and the fan stops as well? What is the model of the air conditioner?
Jun 29, 2009 | Coleman Mach III Air Conditioner
Turn on air, and air kicks on, but no cold air... installed new compatible thermostat but still no luck... Is it the freon low or is it something else? Please help im BURNING UP
Your problem description is quite broad. There are a variety of factors that may cause your AC to not cool your house. With that said, given your ambiguous description, I can offer you a diagnostic article that provides the most probable causes of your AC's failure to cool your house, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Of course, as you alluded, a low level of Freon/refrigerant may be the problem, but there may be other problem causers as well, as noted in the article---it may just be that debris is obstructing your AC as well. Read the article, and, if need be, take advantage of the link for free quotes and "pick the brain" of these technicians who offer you a free quote to discern what could be the problem.
Brad
Jun 08, 2009 | Samsung AW0603B Air Conditioner
Buttons
F1, F2, and F3 are the strength of the fan blowing the air conditioner. F1 circulates the least amount of air, F3 the most. I generally find that if the air conditioner isn't getting the job done on F1, F2 will do it. I typically only use F3 if I just want to circulate air fast in my place for awhile. As far as what is "better" with closed vent or open, that depends on what you want to do. If you are using air conditioning on a hot day, then vent closed is better because it will cool only air circulating in your place. Vent open will allow fresh air in from outside, and if it's a really hot day, the air conditioner might have a harder time cooling off the fresh air than the circulating air inside your place (as it's continually being cooled repeatedly by your air conditioner).
Jun 10, 2008 | Goldstar M1003R Air Conditioner
Samsung AW0603B Air Conditioner Logo
93 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
