Question about Ricoh Aficio 1035 Copier
1035 ricoh aficio printer with error code 322
1035 ricoh aficio printer with error code sc322,That is what happened there was toner on the sight glass and I pulled it out to clean and the toner must of fell into the laser area because before this everything was working fine....Thanks
    New Friend:
  • 22 Answers
Yes, the code is caused by toner getting into the laser unit. The laser unit likely only needs to be cleaned out. To do so, turn the machine of with the red rocker switch on left side of the machine. You will need to remove the front cover and the brown cover behind it. The mechanical counter is plugged into the brown cover so be careful not to damage the wires. The laser unit is the black plastic case you will see behind the brown cover. Be sure to remove the necessary screws and connectors. Be extra careful of the ribbon cable, it kinks easily and the contacts are easily damaged. The Laser unit will slide out, and you can remove the screws holding the top cover on. After removal, clean the interior of the case and mirrors. Do not use any liquid to clean it, preferrabley canned air and a lint free cloth. After cleaning, reassemble, turn the machine back on, and test.
Posted on Nov 19, 2009
  • 31 Answers
You only got toner dust inside the LDU ***'y. 3 Screws and it comes off the laser unit, just blow it out with some air and it's fixed. No need to clean out the whole unit.
Posted on Jan 02, 2010
Ricoh aficio 1035 copier gives error code 390
TD sensor defective
TD sensor not connected or disconnected damage
Poor connection between the TD sensor and IO board
IO board defective
Toner supply defective
* Insufficient toner in developing unit
Apr 16, 2014 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 gives ERROR CODE SC322. CANT TAKE ANY COPY OF IT, PLZ HELP
that mean laser unit have proplem synchro 1 can't detect do with me 2109 and 2108 via sp mode if it's not work out change it
Jan 14, 2011 | Ricoh Aficio 1035 Copier
Code error sc322
laser error code polygon mirror motor bad -Carl
Dec 06, 2010 | Ricoh Aficio 1035 Copier
SC 322
sc 322 how to solve this error
Jun 16, 2010 | Ricoh Aficio 450 Copier
Please solve this problem Ricoh 7650 Code SC 902, 302 and 322
SC322: Laser Synchronization Error
Definition [B’]
The laser synchronization signal cannot be detected from the synchronization
detector even if the laser diodes are activated.
Possible Causes
• Poor connection between the laser synchronization detector and the LDB
• Laser synchronization detector out of position
• Laser synchronization detector defective
• LDB defective
• SICU defective
• Front door safety switches defective
SC302: Charge corona output error 1
SC902: counter error
Mar 31, 2010 | Ricoh Aficio 1035 Copier
I took the laser box out on my 1035 ricoh aficio and cleaned it out but I also took off the switch do I have to recalibrate this some how? error sc322 keeps coming up. Thanks Again Todd
No calibration, but make sure the mirrors are set back correctly and that the polygon mirrors are squeaky clean. Even a fingerprint will make it go wacky.
Nov 20, 2009 | Ricoh Aficio 1035 Copier
I HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Nov 18, 2009 | Ricoh Aficio 1035 Copier
Sc322
1st laser synchronization error.  It is an expensive part to replace and in most cases its cheaper to by a used Ricoh.  There are some 1035s and 2035s out there that run around $700 in American dollars.  If you can find them.
It's possible there could be something going on with the power supply.
The toner spill can vacuumed as well as the optics and the rest of the machine can be cleaned simply with cleaner.
Nov 01, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
1,155 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
