Question about Brother LS-1217 Mechanical Sewing Machine
My needle won't pick up the bobbin thread
I was sewing and my thread broke. (I believe I caused this problem). I was sewing through (what I think now) was too many layers. When I rethreaded my needle and tried to pick up the bobbin luck. I think it's the timing (due to what I have been reading online). I have changed the needle, put in a new bobbin, cleaned inside the bobbin housing area (taking it apart first), and still no luck. It almost appears like the needle is not going low enough (but who knows, I've never had this problem, so I've never actually looked at this before. That might be perfectly fine).
If it is the timing, can I fix it myself? This machine was relatively inexpensive so I wouldn't want to pay a huge amount to fix it. I've also had it for close to 10 years, I think.
  • 5 more comments
  • sewing mama Feb 09, 2008
    i also have this problem. was not sewing to many layers.heard some clanking and then would not sew....i did the same things to fix and nothing.i have a new home machine......could i please get some help also......?
  • LEO0651 Feb 18, 2008
  • Jitka Mar 25, 2008
    I sewed on numerous thick patches onto a Pathfinder uniform and the stitch began to not complete. The needle picks up the thread from the bobbin but will not pull it tight. I have changed the needle, cleaned the bobbin case, adjusted the tension, rethreaded every part ... but to no avail. I do not know what to do. Help!
  • Seamistwishe May 13, 2008
    I am having the same problem helpppppppppppppppppppppppppppppppppppp
  • Anonymous Sep 28, 2008
    Needle won't pick up the bobbin thread
  • roseandjimmy Oct 23, 2008
    Yes, this is also my problem. Please help me someone!
  • marshcinn Feb 26, 2009
    I was sewing a couch cushion and heard a clugging noise and the bottom thread stopped sewing. I took the bobbin case apart, adjusted the tension, did everything I know to do.
My sewing machine is a Brother LS1217, well actually it is my son's, and he uses it very seldom. I went over to put in a new needle and I cleaned it top and bottom, put in a new bobbin, and a new needle and the needle won't pick up the bottom thread. What am I doing wrong? Please help me!! It has to be something simple, as this is such a simple machine!
Posted on Oct 23, 2008
My needle not picking up the bobbin thread. When I remove the needle plate, then the needle took the bobbin thread,
Posted on Oct 06, 2010
I simply need to know how to thread the machine to get started.
please help me with what i thought was going to be a simple solution
Posted on Feb 12, 2009
I am having a problem with my Brothers Sewing Machine LS-1217, not picking up my bobbin thread. But,.... I have never oiled it before?!?!?! Also I sewing sticky back vecro, ruining the needle, I changed the needle and this problem is still happening? HELP!
Posted on Oct 22, 2008
I have the exact same problem.. No Idea what to do.. Will anyone help?
Posted on Sep 13, 2008
  • 111 Answers
SOURCE: Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Posted on Jun 11, 2009
  • 17 Answers
SOURCE: needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Posted on Oct 14, 2008
  • 2702 Answers
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
  • 53 Answers
This is a top tension issue, you need to check two things,
-make sure you thread the machine with the pressure foot up ( this allows the tension discs to open up so you can pull the fabric away from the machine with the foot up and allows the thread to get to bottom of the tension discs)
-make sure your tension settings are set to the medium setting. (Usually 4 or 5)
If this still does not help, then turn the top tension knob up (from 5 to 6,7,8,9....)
-If that still doesn't do it, your probably need the tensions reset, and your local family sewing store will be able to assist you further.
Posted on Jun 06, 2010
  • 3006 Answers
SOURCE: The thread is bunching up
Your problem stems from the faulty foot lever mechanism. It's coupled to the upper thread tension control which only provides tension when the presser foot is in the locked down position.
If the presser foot won't positively engage in the down position, there's no upper thread tension and the thread bunches up below. Everything else stems from there. If the needle has hit the bobbin case too frequently then the bobbin timing may also be slightly out and the needle itself will be damaged and won't pass straight through the fabric; it only takes a tiny deflection from the vertical as it passes through the workpiece for the needle to flex and hit the bobbin case.
In summary, your machine is in desperate need of repair and adjustment. You haven't stated which exact Singer model you have, but they are usually easy to get servicing manuals for or you can take the machine to a sewing machine servicing specialist. Most singer spare parts (even for 100 year old machines) are usually still available fairly cheaply from a variety of sources, just enter "Singer spares" into your search engine to find suppliers.
To prevent re-occurrence, clean the mechanism regularly and lubricate it as directed by the manufacturer using sewing machine oil. Depending on how often you use the machine, do (or have done) a more thorough service periodically to check the timing and also that all mechanism screws remain tightly fastened.
I hope that my reply has shed some light on your problem and enables you to decide what to do next. Please take a moment to rate my answer.
Posted on Sep 30, 2010
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Feb 06, 2016 | Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
My Janome needle thread will not pick up the bobbin thread! I have checked threading and needle and bobbin case...nothing works!
Your Machine is out of time, you probably broke a needle or sewed over a pin. take the machine to your locsl deler to be re timed. about 90.00
Jun 13, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
May 24, 2009 | Husqvarna Viking 1
Needle will not pick up the bobbin thread try there web site
Feb 18, 2007 | White Sewing White 3032
Brother LS-1217 Mechanical Sewing Machine Logo
2,215 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
