Question about Sony KP-51WS500 51" Rear Projection Television
Picture fades in and out to the color blue. sometimes entire picture is blue
  • SD Tech
    SD Tech May 11, 2010
    there is a way to try to adjust the set to cure this problem. Do you want to know what to try? SD TECH
  • 273 Answers
Id check the blue screen control first
its at the bottom of the set you will have to take the front panel off and behind it is another small black panel remove that one
and to select any function those controls need to be attached so slide that front panel to the left there and take you remote put the tv on video input
and there are sic controls on this little black screen control block
look for the screen controls and turn the blue one just slightly clockwise and you will see the blue screen will light up and you will have little arched lines turn the control back slowly till the lines disaper and the screen goes black
and then cycle the set off give it five mins or so and restart it and see if every thing returns and your video is being displayed then switch it back to your input and view and reassemble
Posted on Nov 19, 2009
The color on my Advent TV fades in and out of the picture, and goes to black and white Why
The problem is in the picture tube board circuit. Sometimes the CRT socket doesnt connect well to the CRT pins. Or maybe there have bad solders from RGB transistors. check those transistors, Also the bad thermistor discolored the entire tv screen.
Sep 29, 2014 | Televison & Video
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
MY monitor is very distorted.
Try disconnecting and reconnecting the cables. Sometimes this is a cable connection issue.
Mar 20, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Is this fixable??
Unfortunately, this sounds familiar. Many of these sony projections had bad crt's.(picture tubes). Now here is a secret I learned along the way. The short in the picture tubes is in the filament, causing that color to overpower all others and sometimes causing pix to disappear until set is shut off and back on. If you are very careful and use an insulated screwdriver, you can sometimes tap on neck of picture tube and knock debris from filament causing extended tube life. This is dangerous and must be performed with set turned on. From front of set gently tap on neck of tube(s) in question using insulated handle of screwdriver to make contact with picture tube neck. Picture will probably flash whichever color tube is contacted. Eventually, if picture stops flashing that color as much, you can sometimes get several more months out of your set without any problems. Only alternative is to try a crt rejuvinator or replace tubes at a cost of 200.00 each if avail. plus labor. Good luck, Russmann.
May 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Color fade
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 11, 2007 | Hitachi 51F500 51" Rear Projection...
Zenith Dual receiver PIP 27 " standard "portable" TV color problems
from sympton it looks to me that you should go for new one.
Oct 05, 2007 | Televison & Video
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Faded colors
If the picture is dark or messed up too bad, the magic focus will not function, are all the primary colors faded? RED GREEN BLUE? You might have a bad CRT, would call a service man to check out.
May 21, 2007 | Samsung HCN5527W 55" Rear Projection...
Loose Picture (Goes completely Black)
Nothing special about that board as I cant seem to find that # but If my memory serves me correctly it sounds like a crt board and its a simple soldering job on the crt socket?? Altough Im not there to see the set still 550.00 seems like an awfull lot to repair a set even if they have to replace the entire chassis. I think you should cal rca and take it to an authorized RCA repair center and if the shop you took it to was an rca authorized center I would also report that to them(RCA). Good Luck
May 16, 2006 | RCA MM32110 TV
Sony KP-51WS500 51" Rear Projection Television Logo
189 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
