The brightness screen is stuck on my monitor in the middle of the screen, the number is 100 but the wee black triangle is still lit as if it is going higher, if you manually lower it with the button the bottom of the monitor it will go down but as soon as you release your finger it goes back up by itself
BRIGHTNESS CONTROL PANEL IS STUCK ON MONITOR SCREEN, CANT REMOVE IT.
Posted on Jan 08, 2010
    Master:
    Sergeant:
  • 460 Answers
Your monitors buttons are not working.you can repaired it from service center.
Posted on Nov 19, 2009
Samsung monitor brightness indicator stuck in middle of screen and won't disappear
its an option pyshically on your monitor there has to be some butttons near the power button of the monitor. play around with those and you might figure it out or
http://www.eanswer.com/tv-repair/?r=ppc'ga'9'HI%20-%20Electronics'TV%20Samsung&JCLT=Samsung&JPKW=samsung%20screen&JPDC=S&JPST=&JPAD=5822362509&JPAF=txt&JPCD=20100518&JPRC=1&gclid=CPqM5LPxlLUCFYVFMgodOiUA5w
if this helps please take time to rate
Feb 01, 2013 | Computers & Internet
My lifebook has a black screen but windows running
It could be the monitor or graphics card or CCL are done. Or maybe a simple small switch that shuts-down the light when the lid is closed. I repaired a HP that the switch had "stuck" in the closed position, you could see the screen in the bright sunlight and see the windows OS. The background light,CCL in older machines, was not lit. I once had to access the rear of the monitor, in a laptop, to re-insert a loose ribbon cable that had jared loose causing the screen to go dark.
Oct 29, 2012 | Fujitsu Lifebook P8010 Notebook
Samsung T240 No Backlight
Look like your monitor is gone bad on you. I am not sure if you can get the parts you need. I would get another monitor form a friend and see if your monitor is gone bad. if it is I would get me a replacement. in the long run you will save some money.
Mar 24, 2012 | Samsung T240HD 24 LCD HDTV
I constantly keep seeing "brightness 100"
Check out this link to the manual. It looks like your "On Screen Display" is possibly locked. This should help you unlock it if that's the case...
http://downloadcenter.samsung.com/content/UM/201002/20100208161857906/BN59-00992A-01Eng.pdf
Oct 31, 2011 | Samsung SyncMaster T220 22 inch Monitor
I have AcerPower Series Desktop PC with AC713 Monitor. My problem is in the middle of the screen BRIGHTNESS with 0% of its adjustment go on displaying which hampers my work. Even it's not able to...
Good day,
It seems your monitor is the problem maybe the button is stuck or something. Try bringing it to the nearest service center.
Tnx.
Aug 18, 2011 | Computers & Internet
Probably not only because I found several forums and the same claim as is my case .. initially function to adjust the brightness automatically .. 100% ... like I keep the button pressed continuously .....
Check out this link below for a PDF manual for your monitor. You can also update your drivers. There is a support here also. Just copy and paste into your browser.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=720N
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 04, 2009 | Samsung SyncMaster 720N Monitor
Birghtness 100 Popup
sounds like your "brightness" button may be stuck. try pushing it and see if it feels the same as the other buttons (should feel it "click" a bit). Also see if any of the other buttons work, because if it IS stuck, they probably won't work...
Nov 29, 2007 | Samsung 710N V2 17" LCD Monitor
Popup on monitor screen
first try unplug set from AC plug for about 10 seconds for full system reset.If not see if firmware (software) on set could be updated to newer version software...could be a software issue..
Nov 28, 2007 | Samsung 710N V2 17" LCD Monitor
134 people viewed this question
k24674
jasbo
jasbo
