Question about Dell Computers & Internet
Dell Laptop BIOS password recover
I have a dell Studio 1555 laptop with bios version Ao6. I put a password on the BIOS setup and forgot the password..I can't access my BIOS setup anymore. Please help ! is there anyway i can recover or reset me BIOS setup password
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
A reliable method can be found here:
http://www.cgsecurity.org/
look for Password recovery.
Try the backdoor password Dell
: all bios passwords can be removed easily,
: 1-create a dos system disk,
: 2- copy "debug" (this is a dos command found in windows\command directory) onto the system disk you created,
: 3- boot the machine with this disk,
: 4- at dos prompt type: debug then enter, you will see a blinking dash
: 5- type: o 70 2e then enter, (also seen: o 70 18)
: 6- type: o 71 ff then enter,
: 7- type: q then enter,
: 8- remove the floppy and reboot! Power the system off and on by unplugging and re-plugging the system into the power outlet
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 19, 2009
Dell latitude D610. Bios Revision AO6 Anyone Help?
try to remove bios battery on the inside and short the pins with something iron like a screwdriver for a few seconds, remove the battery pack too when doing this, you should be fine after that,
ps. you might need to set some bios parameters when starting up again
Nov 03, 2016 | Dell Computers & Internet
Hi. Can someone help me with the BIOS password on my dell latitude e5500? Service tag is: 7KBVQ4J
Hi Mar Mar,
As far as I know once the you forgot your BIOS password no more options to get it anymore. You may also wanted to talk to Dell Tech Support 1-877-542-3355 in order for them to check if they can still do something about it. Worse scenario would be replacing your MOBO.
Apr 25, 2014 | Dell Latitude E5500 Laptop
Dell Bios Updater. Unable to see current version and will not update BIOS.
Ensure that the AC adapter is plugged in, the main battery is properly installed, and a network cable is attached. Turn on the computer. Locate the latest BIOS update http://www.dell.com/support/drivers/us/en/19/DriverDetails?driverId=R301502
Feb 04, 2013 | Dell Studio 1555 Laptop Computer 15.6-Inch...
Dell inspiron 700m break the password
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-700m-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Dec 01, 2011 | Dell Inspiron 700M Notebook
Dell inspiron 1501 phoenixBIOS setup utility Password
Go to: http://dell-inspiron-1501-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Oct 06, 2010 | Dell Inspiron 1501 Laptop
I have a DELL STUDIO 1555 laptop. Well due to some over confidence, I started installing the same BIOS version again which was already working fine. But as it was re- installing the same BIOS version ,...
Hi. You might have damaged the motherboard by removing the power source while it's flushing the BIOS. Check if your system is still in warranty. Otherwise, you may need to replace your motherboard.
May 18, 2010 | Computers & Internet
Unlock dell inspiron 1521 unknown bios pswd
Go to: http://dell-inspiron-1521-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Feb 12, 2010 | Dell Inspiron 1521-JB Notebook
Dell Inspiron 8000 when I go into cmos(setup)F2, there is no control working. arrow keys do not work
Go to: http://dell-inspiron-630m-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Oct 02, 2009 | Dell Inspiron 8000 Notebook
How do I remove forgotten BIOS password?
1) You can reset BIOS to default settings by pressing <Alt><F>
2) I am not sure about the laptops, but in the Dell Desktops usually there is a reset jumper on the motherboard which is seated on 2pins out of 3, you just need to remove that jumper turn on the pc once and the turn on the pc again by reseating the jumper to its original place. You can try this with your laptop, I guess the jumper should be somewhere close to the CMOS battery.
3) Remove the battery and keep it away for atleast 30 mins. and replace it again.
NOTE: make sure while following step (3) and (4) the system should be completely turned off. Unplug the AC adapter, remove the battery and hold the power button for atleast 8 - 10 seconds.
let me know the output
Aug 29, 2009 | Dell Studio 15 Laptop
How to Unlock Dell inspiron 1520 Laptop Password
I is my understanding that you can contact Dell with the service tag, and express code and get the master password to clear forgotten passwords.
May 09, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
1,957 people viewed this question
Alun Cox
