Question about Gigabyte GA-8I915P Duo Pro Motherboard
Hi, Sometimes here the buzzer working.I check FAN's and temperature and every thing is ok. How can I know where its come from? Thank Ami amibe@nana.co.il
  • 235 Answers
It depends if there is no display in you're computer and you hear is only a buzz first if the buzz is long you have to check your memory module (try cleaning it and put back again if the buzz continues its time to replace it) second if the buzz is short and had interval then the problem is your vga card (built in or a separate card - agp or pci-e) if you have a built in vga then just add a vga card now it depend on the motherboard what kind of expansion port it has (agp or PCI-e) hope this help
regards,
Michael Ibot
Posted on Nov 19, 2009
Fan wont come on when temp is reached
I assume you mean the cooling fan. Start with simple things like checking the fan relay. If that checks ok try tapping on the fan motor when the engine is up to temperature. If the fan starts working you know it is the motor. Anything more involved than this go to a mechanic.
Jun 14, 2014 | 2002 Jeep Grand Cherokee
My projector will go off after 5-10 minutes, started with longer periods like 30mins or more... Sometimes it worked without any problems. It has a new lamp on it and Im not sure what can be the problem?...
hi,
First of all check the lamp hour of your projector. Just reset it and try again. for resetting the lamp hour do the following.
1.Switch on the projector
2.select menu and the select lamp setting
3. In the lamp setting menu select lamp Reset and execute the same
After doing this if the problem remains then you have to check two things. first you have to check the lamp cooling fan of your projector. If the lamp cooling fan of your projector is faulty or it runs in a low speed this problem can occur. Another possibility is the faulty temperature sensor. you have to check the temperature sensor near the lamp. normally a senor with two wire fitted on the lamp Cage.
if fan is suspected then remove the fan and try to oil the fan and the re fix it and try again. for oiling the fan watch the following video.
The video is for oiling a pc fan you can follow the same to oil the lamp cooling fan
ok
Apr 20, 2011 | ViewSonic PJ406D Multimedia Projector
A Trane 20 Ton roof mount A/C unit model # YCD241B4L0DD does not work... Test sequence works OK through it's steps but after power off reset jumpering TB1 to call for max cooling 1+2 does not...
Hi
Please check the bellow link to diagnose what could be wrong with your AC…
http://www.inspectapedia.com/aircond/aircond1123.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 24, 2010 | Heating & Cooling
F2 signal on Jenn-Air model su146 range
Hi there
i have found the code for and hope this helps you.let me know how it goes.
F2 Oven too hot Replace relay board (if present) or oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | Kitchen Ranges
Automatic headlights don't work all the time on 1999 Buick Regal GS with 144,000 miles. Intermittent problem. Sometimes they work and sometimes they don't. I always keep headlight switch on middle...
hi,
you had specified as, the headlights are not working properly & making a buzz sound.The problem is the circuit has a loose connectivity either at the switch or near the bulb. while you are able to hear the buzzing sound check the position of the wires near the source of sound. You will be able to find where the connectivity should be tightened exactly.please do this as early as possible since the loose connection can damage the circuit and the switches due to high temperature.
thanks, have a nice day.
Feb 09, 2010 | 1999 Buick Regal
After it is working a buzzer starts going off and reading F4
HI. this is a shorted or open oven temperature sensor error code.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 13, 2009 | Maytag 30" Built-In Double Electric Wall...
Electric fan on 87 escort gt wont come on I cant find a manual so I would like to know where is module. The fan worked a couple of days ago. also what is the way to check fan? I checked fuses under dash...
Check by your oil dipstick, in front of distributor , there should be a temperature switch threaded into cylinder head that controls cooling fan.
Sep 15, 2009 | 1987 Ford Escort
Evaporator fan has stopped working
Check and make sure the other two connections are solid.sometimes when the fan gets unplugged, the terminal gets loose and looses connection where it is soldered into the fan motor. Some models need to be a certain temperature in order for the fan to work. You can check voltage to the fan also. There should be 120V to the fan. Makes sure the fan/light switch is pushed in (on some models). If I can assist you further, please let me know.
Thanks
Vic
May 22, 2009 | Refrigerators
1994 2.2L toyota camry radiator fans do not work
Hi.....
The Normal Temperature Range to the Fan Start is: A/C ON 181 F.
A/C OFF 199 F. When the Engine Reach this Temperature the Fan should start.
OK. Do this simple test.
1---- Start the engine, Desconnect the ECT Switch located on the Radiator,
See if the Fan come ON. If yes, if not go to step #2
Connect the ECT SWITCH and leave the car Running and with a Temperature gage.
See the temperature, if the Temperature go more than 199 F.
Turn the Engine OFF.
Disconnect the ECT sensor and check for Ground at the WHITE/BLACK wire.
If ground exist, Replace the ECT switch.
But if not. Check the wire for any damaged, and the ground at the Front Left Fender.
Repair as need.
2---- check the Fuse link RDI FAN . 30 amp.
Check the Fuse link CDS FAN 30 amp.
Replace if need.
And Return to step # 1.
Check the Radiator fan Relay, Rad fan relay 2 and 3. Replace if need.
Ok. I hope this help on your question.
I can give to you the WIRING DIAGRAM of the Fans, But I need a E-MAIL adress to do that.
Thank you for use fixya....
Sep 25, 2008 | 1994 Toyota Camry
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Gigabyte GA-8I915P Duo Pro Motherboard Logo
    141 people viewed this question
    Top Gigabyte Computers & Internet Experts
    David
    David
    Alun Cox
    Tony
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
