Question about Nokia N73 Cellular Phone
I normally doesnt use my mobile phone every minute it just sits in my desk but sometimes it shuts off even if the battery is fully charge
    Sergeant:
  • 297 Answers
Your phone and memory card ...memory might b damaged....format them....first format your card then remove it then.......format your phone with this code *#7780#..........it will help u
Posted on Nov 19, 2009
Xperia Play Battery Drain and screen malfunction during charge.
Apps and services in the background drain your phone even while in standby mode. Turning off your 3G or 4G connection will deprive you of the internet but it will still permit you to get phone calls. Meanwhile, you are not having apps such as Google constantly draining your power in the background. And they are, even in standby mode. Charge your phone frequently to help preserve battery life.
Sep 17, 2017 | Sony Ericsson - Xperia PLAY Mobile Phone -...
Mobile phone battery goes flat after five minute call even tho it is fully charged ... what to do
Each battery type has their service / time limit . It may the time to replace your battery pack with new one. But before decide to replace the battery, make sure your charger is working properly while charging your battery.
Aug 24, 2011 | Motorola Mobility W510 Mobile Phone
My htc touch mobile gts switched off automatically though battery is fully charged and is new.is there a software problem or what?after getting off it doesnt start very easily.again i ve to start charging...
you have a mobile with an isemetric fault its built into the pcb due to bad current draw the only way to fix it is to replace the whole pcb if its new take it back if its under warrenty get it fixed or youl have this trouble for the remainder of the phones life.
this fault normally comes with the phone. it is not a fault that it picks up along the way
best of luck
please take the time to rate this advice
merry christmas
Dec 07, 2010 | Nokia N73 Cellular Phone
My K810i phone doesnt turn on..
let it sit in the charger for 1hour then try to turn on your phone. it could be that the charger cannot charge the battery and turn on the phone at the same time and the battery is too weak to turn it on and needs a better charge.
Nov 11, 2009 | Sony Ericsson K810i Blue Smartphone
I charged my battery yesterday and waited until it was fully empty. Now the battery doesnt want to charge anymore. I thought something was wrong with the phone and I entered my other battery. It is now...
There is nothing related to battery in this case, I guess. There may be problem with your charger connector. Just put the battery to another mobile and try charging. It it works then the problem is with your mobile connector only. You have to use genuine compactible charger for your mobile.
I hope this is helpful to you.
Nov 07, 2009 | Computers & Internet
RAZR V3m shutting down randomly
You may try putting a small, thin piece of b under the battery directly on top of the small metal tab, put the battery back in, see if this pressure is enough to keep your phone on.
Sometimes the cell phone deals people are getting on Ebay actually result in more frustration and disappointment.
You may consider cutting your loss and purchasing a new phone, or getting a FREE phone from one of the major carriers.
I highly recommend the following company for getting your next phone, the customer service is excellent and the selection is great. I also recommend folks in getting insurance on their new phones as well. I hope this helps you, best wishes :)
http://shop.acnwireless.com/mobile/?r=acn&eid=01958203
Aug 31, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Low battery
leave the battery drained out, when pop up appear saying LOW BATT turn off the phone remove battery for 5 minutes, then reinsert but DON'T turn phone on. Leave it off and connect charger, you will see moving battery bars when charging started (sometimes takes few minutes). To fully charge the battery keave it on 4 hours.
Jun 26, 2009 | Nokia 6300 Cellular Phone
Laptop suddenly shut off and will not turn back on
Sometimes the voltage regulator in the battery hit a point where they fall below a certain efficiancy % they have to operate at. Once they fall below that % you must replace them, even if the battery is 100% charged. Its usually a good idea to pick up a new charger as well with a new battery since they are known to die as well. Make sure you check the socket in the back where your charger plugs into the laptop to make sure its not loose or cracked. Sometimes the plug will crack off the motherboard and not make good enough contact.. But regardless of that it should atleast turn on if the battery was charged and good. Best bet, new battery. Every 2 years you should get a new one.
Jun 04, 2009 | Toshiba Satellite M45-S269 Notebook
My Nokia 2310 will not power on.
Take out your battery. Let it sit for thirty seconds to a minute and then replace the battery. Sometimes all of the juice gets used, even when it is fully charged. If that does not work, you may need to take it back to your carrier and have it looked at professionally.
Please rate FixYa!
Jan 12, 2009 | Nokia 6080 Cellular Phone
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
