Question about Siemens CX65
The joystick doesn't work - Siemens CX65
My ps2 joystick L3 button stuck when i derict it to any direction .. it suppose to back into its center position but it doesn't it stuck and still unmoved untill i move it back to its original pos
I would suggest buying a new controller if you want to skip the hassle of trying to fix this one, but if you insist on keeping this controller, then there could be a way to fix it. First try your best to smoothly trace the joystick around in a circle, and see if that unsticks it. If this doesn't work, apart from buying a new controller the only other thing to do would be to open the controller up and put lubricant on the bottom of the joystick, this will most likely work, but you might damage your controller in the process.
Oct 11, 2012 | Sony PS2 Dual Shock 2 Controller...
My joystick doesn't works in god of war 2 in pc game
Check the settings of joystick in game controller and god of war 2 setting (in game). check them this solution is for joystick not working on in a particular game.
Aug 20, 2012 | Electric Toys
Having trouble programing my extreme 3d pro joystick and FSX deluxe. I am using Vista. I can't get the elevator trim up/down to work. Doesn't even seam to work when i press 7 or 1 on the...
I would first of recommend doing a calibration of your joystick. To do that, make sure your joystick is connected to your computer and go to your start menu>>devices and printers. Once your window pops up, find your joystick and right click on the icon, and go to settings. You can find the calibration wizard there. Once that is done, open up your Flight Simulator X, and go to the settings tab. Along the right hand side, click on controls. From there you can configure your joystick buttons to whichever action you like. Please keep in mind as well when your are adjusting the elevator trim, rudder trim, that the adjustments made from one keystroke, or button push, are very very small adjustments. You can change that by moving the slider on the Repeat column, thereby making one keystroke or button push equal to multiple taps!
Sep 13, 2011 | Microsoft Flight Simulator X
I have the heavy gear . i've changed my joystick, but the game doesn, recognize the new one
In Windows 7, Go to "Game Controllers" in your control panel, select your joystick from the list, click "Advanced," and under "Preferred Device" select your joystick from the dropdown menu.
It worked for me with my MS Sidewinder FF2 and Windows 7. BTW, SloMo is highly recommended to play Heavy Gear 1, as otherwise your gear will run in place in the game because it's running too fast.
Feb 27, 2011 | Activision Heavy Gear for Windows
Passcode for god of war2 pc version
my joystick doesn't works in god of war pc
wt can i do
Feb 26, 2010 | Intel Video Game Consoles & Games
Joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
Mar 22, 2009 | Logitech Attack 3 Joystick
My joystick doesn work at all
you need to replace the joystick inner keypad check our parts shop on ebay 4onesexpress-07802458019
Nov 06, 2008 | Sony Ericsson K750i Cellular Phone
Dx7630 kodak easyshare
the 5-way switch breaks it's solder connections on several Kodak models. if you have a soldering iron with a fine tip and are comfortable working on small soldering joints it is possible to repair the joystick (there are 10 solder connections on a 1/4 inch square switch, 3 on two sides and 2 on the other two sides)
Sep 29, 2008 | Kodak EasyShare DX7630 Digital Camera
Not working help
joypad doesn`t work well ob fifa 09
Jan 19, 2008 | Saitek ST290 Joystick
Cell Phones Logo
136 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
