Question about Sharp 25N-S100 25" TV
Our TV won't turn on when we press the power button it clicks but doesn't turn on the monitor. When we opened the TV set up, we found a little device on the switchboard that makes the click when we hit the power button. It sometimes sparks too. Occasionally, the TV randomly works fine, but usually-- nothing! (1997 JVC)
  • 979 Answers
Good day sir, hi, as you know it is dangerously working with this type of appliances, you should let the diagnosis to an expert in TV, or else more damage may happen, worst you may get an electric shock.
The problem part MAY be anywhere in the power supply section, a faulty voltage regulator, an open low value resistor, a leaking capacitor, or a defective switching controller IC, this are to be checked thoroughly.
Posted on Nov 19, 2009
1990 panasonic tv model# CTM-2783S won't turn on
the tv need for servicing, the cause is either bad regulator transistor in the power supply section or shorted horizontal output transistor. that is why the main circuit board doesn't get to turn on. to do the repair just ensure you have knowledge in repairing tv.
Nov 17, 2012 | Televison & Video
The TV won't turn on. The little light by the power button doesn't even come on
Blown fuse caused by a shorted power supply. Relacing the power supply board should solve the issue in most cases. You can get a power supply board from www.tvrepairworld.com
Oct 27, 2012 | Polaroid LCD-1700 17 in. Television
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
How do i turn off power save mode using the screen buttons
I don't know if there is a monitor with a function button to turn off the power save mode.
As far as I know the power save mode of the monitor can be found in the display setting of the windows..
Anyway... If you want to turn off the power save mode of the monitor via windows display setting then here is what you need to do:
On control panel, double click display settings.. click the screen saver tab... on the lower portion Press the "power" button.. Select power schemes tab.. Change the settings of" turn the monitor off" to "never"
Click apply and then OK..
Hope it gave you an idea..
Much appreciated if you rate this help...thanks..
Uncheck the box
May 19, 2010 | Dell E173FP 17" LCD Monitor
Helpme please
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Philips 150S4FB 15" LCD Monitor
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Monitor will not wake up when pc is turned on
How do I disable the power, sleep, and/or wake buttons in Windows? Answer: Disable the computer's ACPI feature If you wish to disable all three of these buttons, you can disable the computer's ACPI feature in BIOS / CMOS. Additional information about how to enter the BIOS / CMOS setup can be found on document CH000192. Once in BIOS / CMOS setup, you can disable ACPI in the power category. The location of this option is almost always different between all BIOS manufacturers and versions of BIOS.
Change the power option within Windows Microsoft Windows XP users By default, Microsoft Windows XP will prompt you what to do when the power button is pressed on the keyboard. If you wish to change this setting, follow the below steps.
  1. Click Start / Settings / Open the Control panel
  2. Within the Control Panel click Power Options
  3. In the Power Options Properties window, click the Advanced tab.
  4. Under Power buttons, click the down arrow under "When I press the power button on my computer" and/or "When I press the sleep button on my computer" and select the action you wish to perform when pressing the key.
Microsoft Windows 2000 users Unfortunately, Windows 2000 does not have all the features Windows XP does. However, you can change the power button or other buttons to perform a different function. For example, changing the power button to suspend instead of power. To do this, follow the below steps.
  2. Within the Control Panel, click Power Options
Good Luck, Please dont for get to Vote, Thank You.
Dec 23, 2007 | Mercury P4VM800M7 Motherboard
Sharp 25N-S100 25" TV Logo
99 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
