Question about Sony Walkman SRF-M70 Radio
The time is flashing on the screen and it continues to flash. Can't turn on the unit, change time, etc? It's like it is locked out somehow.....do I need to push a couple of different buttons to turn it on? Is there something internal that needs to be changed or replaced? Batteries are good. Any ideas on how to fix?
Check the red key protect button on the front top left of the radio. If it is activated there will be a key icon on the screen. Press it once to deactivate it & the key icon should be gone & the rest of the buttons should work.
Posted on Nov 20, 2009
What is the difference between the flash and continuous lighting, why not using continuous lighting for photography?
Two main reasons flash is used over continuous lighting.
Power. Lighting a scene for minutes uses much more power than lighting it for a fraction of a second. You may have noticed that most continuous lights need to be plugged in to a power supply, while most flash units work with small batteries. It may not make much difference if you're shooting indoors in a studio, but if you're out in the field and have to move around, it can get difficult lugging all that gear around.
Duration. A flash unit provides a very brief flash of light while a continuous unit is, well, continuous. A flash can freeze action much better than just using the camera's shutter. Try it yourself sometime: turn on the lights in the bathroom (and/or bring in your continuous light units) and take some pictures of a dripping faucet. Now turn off the lights and take some flash pictures of the same thing. See the difference?
Dec 17, 2013 | Photogenic DigiLight Continuous 500 watt...
Display screen is flashing
Take the unit back to where you bought it, and get them to replace the defective unit.
Aug 01, 2010 | Dymo LetraTAG Thermal Label Printer
Does anyone know how to fix error code #357 with regards to CanonPixma MP780. I cannot get it to print even after changing the ink cartridge...the display keeps flashing "CHECK PRINTER" Please help
Hi
The most common cause of this error, is the purge unit being blocked somehow (small piece of paper, dried up ink, etc.), however, it IS indicated as a paper feed position error, and as such CAN be related to internal mechanical timing on the sheet feeder unit, or positioning of the purge unit in accordance to the positioning of the sheet feeder unit.
My first bet would be to take a flash light, open the top cover, and move the printhead to the far left, checking the purge unit for any visible obstructions or clogging ink
All Best: Pineworks
Jan 23, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Dell latitude d505 wont start up. When I press the power button a flashing padlock shows up but the screen never turns on, then the flashing padlock stops, and thats the end.
The flashing padlock should have an "A" in it. That is the caps lock. The flashing caps lock indicates a problem with the memory slot. Try removing memory and replacing. If it continues and you have two modules, take both out and try one at a time. One of your memory modules or slots might have gone bad
Aug 04, 2009 | Dell Axim X50 Pocket PC
Craftsman garage door opener will not work. model # 139.53648SRT2
The code it is sending by flashing 5 times is 'RPM sensor or motor overload'. Is the door stuck in the open position?
Jul 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Powere locks continuously lock and unlock with lights flashing,etc even when car is turned off.
Doors locking and unlocking, lights flashing. You have a possessed Suburban get a priest immediately! Or you have a short circuit. Try and remember if any work was done to your SUV and in what area. Then look for peeled, scraped or touching wires.
May 06, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Thomson lyra 6675 Flash Mp3 Player 2GB
The unit has a hold button which when you accidentally slide to one side, will "hold" or lock up the unit, to unlock this, simply slide the hold button to the opposite side.
Apr 16, 2008 | Audio Players & Recorders
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Flash icon
Same problem with the red flash icon. I can take a picture if I turn off the flash as well, but have to turn off the flash every time I open the lens. Have had the camera for 5 years and haven't had a problem. We needed to replace the lens cover recently and after we replaced the cover we started having this flash problem. It was working fine before the cover came off which leads me to believe we've changed our settings somehow....pleas
Dec 26, 2007 | Olympus Camedia Stylus 300 Digital Camera
SB800
When you attach the flas to the camera can exidentli fire. This is normal, and manufacturer recomendation, turn off the flas unit before attach or deattach, prevent this fireing. Fireing when you turn the flashead is not normal. Probably the mounting foot of the flash unit can move in the hotshoe, breaking connections between the connector pins, causing exidental fiering. Always lock the locking lever of the flas, wich can prevent this unwanted movement. Also chek the hotshoe on the camera, wich should to have a "leaf spring" keeping the flash unit steady.
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
199 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
