Question about LG 32LC51 32 in. HD-Ready LCD TV
Tv doesn't power on properly and sometimes not at all
  • 979 Answers
Hello Sir, hi, your TV is in serious order, this could be traced from a failure of the power supply board to the mainboard. This diagnostics should be done by a qualified service personnel and should not be performed by a novice. The process is to locate the problem board, first replace the power supply board, then test, if the board respond then good, but if not, then the problem is on the system/main board, we then replace the main board which controls the sound, LCD, controls and the likes. at this point the TV most likely be powering on. But replacing the two boards are costly, so I suggest you take it to your dealer for proper advice on your TV. if its under warranty, much better. they will replace the entire tv.
Posted on Nov 19, 2009
Testimonial: "thanks unfortunatelt it's not under warranty so will have to see what needs to be done"
If my akai flatscreen 32in tv is moved or if the power goes out sometimes I plug it back in and the red light doesn't come on. Other times is when I'm watching it and I turn it off it goes from...
bad joint remove back panel with tv off check for any bad joints on power board also caused by thermal fault with tv on use a heat source over boards till tv shuts down then check suspect board
Dec 23, 2012 | Televison & Video
My grandmother recently gave me her industrial singer 49 d200ga machine, and i love it because it works fine. However, when I brought it home, the foot pedal stopped working properly. How can i get it
Is your industrial machine one that has a big motor mounted under the table? If so make sure the power cored is plugged in. Also if your pedal is not installed properly it will sometimes flip forward get bound up and won't allow the proper throw to run the motor. Since the pedal doesn't supply power check the linkage to the motor.
Oct 03, 2012 | Sewing Machines
Phone startup fail contact retailer message
Hello insert another battery and try it.....if the problem persist contact nearest mobile repairing shop for further examination.Sometimes this problem occurs when the battery in use doesn't works properly Or sometimes it is due to the damage of some components in the BSI line of the phone.Good luck
Aug 27, 2012 | Nokia 5530 XpressMusic Smartphone
My 1996 Olds LSS doesn't idle properly,idling surges sometimes,the temp. gauge doesn't work and sometimes the heater doesn't work.It may stall while driving.If I get in and the power seats...
Your first problem is to find out why the intermittent no-power problem. Honestly, that sounds like a loose conmnection somewhere. check all your grounds for clean and tight conditions Also, battery connections and alternator connections. Double check your power distribution center for any loose wires or poor connections. Once you solve that problem, then you can diagnose the other problems with poor idle and temp. gauge.
Oct 17, 2011 | 1996 Oldsmobile LSS
Our tv doesn't have a picture but it has sound.
Normal problem. Cable connections are loose. Do this Unplug all the cables including the power on Wait for sometime - minute or more. Re connect all the cables. See that they are secured in the sockets properly. Switch on the power. Your picture problem should be over.
Sep 24, 2011 | Televison & Video
I have a Gate SX2800-01, and when I press the power button, sometimes it turns on fine, but most of the time it the power button flashes once, and then the cpu boots up, but the screen doesn't get any...
all you need to do is update the drivers for monitor or the monitor is going out just go your hardware and click on the monitor then update drivers it will tell you if it is working properly
Jul 07, 2011 | Gateway SX2800-01 PC Desktop
My tv was on when a power failure occurred(about 3hrs). the green light is flashing but the tv doesn't turn on. What can I do. Help
I HAVE THE SAME PROBLE WITH MY PHILIPS FLAT SCREEN. THEY TOLD US THE POWER SUPPLY IS OUT IN IT. SOMETIMES YOU CAN BUY THEM ON E-BAYCHEAPER THEN FROM THE MANUFACTURER. HOPE THIS HELPED
May 25, 2011 | RCA L32WD12 32 in. LCD HDTV
Ps3 nodisplay, although I reset output video
minhpham have to tried to insert any disc like moves, song differnt game frm call duty.
and if it dosnt work let me knw.
abdz
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
LG 32LC51 32 in. HD-Ready LCD TV Logo
249 people viewed this question
Computer Repairing
Computer Repairing
