Question about Panasonic NN-T990SA Microwave Oven
My microwave just switches off in 5 seconds. how do i trouble shoot it?
    President:
  • Panasonic Master
  • 1,922 Answers
Check the thermistor on the side of the magnetron tubes body, its usually held on by 2 small screws,it's about 1/2" round and has 2 wires on tabs coming out of it, remove thermistor & wires and clip on ohm-meter and heat the thermistor with a match and see how fast it clicks and the meter goes to infinite from a short circuit which will when in circuit shut power off to the tube it's a type of temperature safety switch for the magnetron tube and it or the tube are faulty, also carefully check the tubes body after operation and cutout and see how hot tube is,it could be the tube going out,but i think it will be the thermistor in the end because if the tube gets that hot that quick it would blow the units fuse due to excessive current draw
Posted on Nov 19, 2009
My microwave will not run. I have tried the trouble shooting tips in the manuel. When I press start it runs for a second then clicks off.
You have a defective control panel, chances are the repair will be more than or close to the cost of a new one.
Jul 13, 2017 | In Microwave Ovens
Microwave hums when door close and power is off
Is it a fan noise you hear? Or is it more like a transformer noise? You may have a bad door switch, or you may have a sticking relay on the control board. You probably need to call a professional repairman to trouble-shoot and repair your microwave oven.
Oct 18, 2014 | Microwave Ovens
I would like to fix a door switch on wolf MW24
The adjustment does not last, the technician should have replaced the door switch from the beginning to avoid a callback and leaving a bad impression. To trouble shoot you will need a digital meter, if you have one one post back.
Jun 28, 2012 | Sub-Zero MW24 Microwave Oven
Microwave won't heat up while in use
It sounds like the unit is in demo mode, they usually have a small d on the screen, try holding the "kitchen timer" pad down for 5 seconds, it should then work, if that doesnt apply to your model look in the trouble shooting guide of your owners manual, it will explain how to deactivate "demo" mode there...Phil
May 18, 2009 | Kenmore 63252 Microwave Oven
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Trouble shoot microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Let us know if the hard reset doesn't fix it.
Jul 18, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
715 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
