Question about Nokia 6680 Handheld
Some buttons in key pad not working - Nokia 6680 Handheld
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Error code SAb bath on Jenn Air oven. Held clock button down for 5 seconds and key pad still will not work.
possible need new key pad.first check no loose connection from key pad to the control board,if not replace key pad
Nov 24, 2013 | Jenn-Air Ovens
The touchpad (and buttons) stopped working. No response at all. External mouse works fine, so it is not a software issue. Could this be a loose connection? or do these fail after a while? Are the...
Is there a button with a light on it near your touch pad, sometimes these buttons don't have lights? Usually this button is centered on the bottom or top of the touch pad. If there is a button like this, then try pressing it to see if it gives you functionality of the touch pad. If you do have a button like this and it doesn't resolve the problem then there is a possibility that the touch pad has malfunctioned or that the connector has come loose somehow. If you don't have this type of button then look at your keyboard to see if there is a function key for turning off\on the touch pad. Look for the FN key. What color is it? Then look at the keys that have icons in that color. If you find one that you believe is for the keyboard then try pressing that key and the FN key at the same time.
Jun 25, 2010 | Toshiba Satellite M55-S325 Notebook
Unable to use touch pad....rt clk and slide key
If the laptop is that new, the problem is probably the touch pad "disable" button. Look for a small button just above or near the touch pad and make sure the touch pad is not turned off. If you cannot find the disable button, look in your user manual for the touch pad disable.
Jun 01, 2010 | Acer Aspire 5100-5022 Notebook
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
I have a Verizon Moto Q. The buttons are not working properly. When I hit the start button, back, the arrows, or center select button, mail button and certain letters it just enters numbers or letters and...
Hi, from the question you posted, there are three likely problems to the phone. One it's either the key button pad is bad which needs to be replace, the interface of the key button pad is dirty which needs to be cleaned, or the glass I.C which controls the key button is bad which also needs to be replaced.
But i think what the problem is the cleaning of the key pad button interface because the buttons are working but they only misrepresent whatever function you try to perform on the phone.
You just need to get a mobile phone technician or an electronic repairer around you to help service and clean the board and key pad button interface, and the phone will start working fine..
Take care
Mar 26, 2010 | Cell Phones
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Samsung- SGH-D820 key problem
Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that.
You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
But if you hawe waranty, use ti!!!
Nov 11, 2007 | Samsung SGH-D820 Cellular Phone
Frozen key pad
I have the same problem. Was not dropped or water damage to my knowledge. Just the red button works. When I open it, though, it shows the asteriks key as being pressed which is under the #7 key. Any help would be greatly appeciated.
Sep 08, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Nokia 6680 Handheld Logo
22 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
phil
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
