Question about Sony Cyber-shot DSC-W50 Digital Camera
No flash even if camera is in auto flash mode
3 Suggested Answers
dg9dotorg
  • 151 Answers
SOURCE: In AUTO mode, pictures are all dark!
Yes you definitely can,
Turn on the camera.
The mode dial can be turned to any setting.
2. Press the button for longer than 5
seconds.
The message “Reset settings to default?” appears on the
LCD monitor.
3. Select [OK] using the left and right
buttons, then press the button.
The normal screen resumes when resetting is complete.
To cancel resetting, select [Cancel] instead of [OK].
Posted on Dec 09, 2007
  • 586 Answers
SOURCE: brand new camera, flash does not work even in auto
The part that needs replacement is given below:
Part Description
A1701267A ST BLOCK ASSY
After replacing this part your camera work fine again. To get this part please click here
Thanks for using fixya.
Posted on Nov 19, 2009
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center.
The flash mode button is the top button on the selector, it has a lightning flash icon.
Press the flash mode button on the multi selector.
Highlight the desired mode and press the center of the multi selector.
The flash modes are:
AUTO; Flash fires automatically when lighting is poor.
AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits.
OFF; Flash will not fire even when lighting is poor.
FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects.
SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light
The selected flash mode icon appears at the top of the monitor.
Oct 22, 2014 | Nikon COOLPIX L3 Digital Camera
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
Why is the flash not working on my vivitar 8025
The Vivitar 8025 has the following flash settings: Auto mode , Fill-in mode , Flash OFF mode. Since the cam doesn't have a manual flash setting, check to see if it's set to OFF mode. Or even Fill-in mode (sometimes it barely flashes). Auto mode will only work if needed......
thanks.
Apr 08, 2011 | Vivitar Cameras
My D40x pictures are all under exposed even in auto mode can someone help me in this should i need to buy additional flash for it
Hi there if in auto mode youe camera gives you under exposer its mean the camera sensor not working properly. May be its damaged. I suggest you before buying the new flash just check your camera from service center. Thanks.
Apr 05, 2010 | Nikon D40x Digital Camera
Can I leave my flash on permantly on.
You better put the flash on auto mode than on always on mode. When you put on auto the camera senses when it needs a flash and fires accordingly. If you leave it on, it will fire for every shot, even when it is not necessary, and it is not good for your pictures.
Dec 23, 2009 | Vivitar ViviCam 8025 Digital Camera
How do I turn off the flash for the canon powershot a630?
First of all, the flash can not be turned off in "Auto" mode. You can turn it off in any mode other than Auto. Would recommend Program "P" mode, which is very similar to Auto, but allows you to modify certain minor items such as flash and white balance.
Rotate your mode dial to "P", then press the button on the back with the "lightning bolt" icon. Press until the lightning bolt with a slash shows up on your LCD screen. The flash is now turned off in Program mode. Try taking a picture.
Remember, if in low light conditions you'll need to keep the camera extra steady without flash to get a clear picture. Recommend placing the camera on a table or chair (or even better, use a tripod), then using its autotimer to snap the picture.
Nov 01, 2009 | Canon PowerShot A630 Digital Camera
Canon S3 IS - Images are darker or underexposed even in normal ambient light. Started happening just recently
If you are shooting using AUTO mode, maybe the settings were changed to a manual modes. If so, check for settings. Flash fires automatically only in AUTO. On manual modes you must force the flash to fire.
Aug 09, 2009 | Canon PowerShot S3 IS Digital Camera
Imagines are dark even in bright light
the flash settings should have been kept in auto mode.if you want the flash always.normally, there is a button near the lcd screen, with the symbol of a lightning flash. when you press it once it sets the flash mode to auto, second time it sets it to "flash always on mode", third time "flash always off" mode.you can refer this process in instruction manual also.thanks for using fixya! please dont forget to rate my solution.
May 29, 2009 | Canon PowerShot EOS D60 Digital Camera
G9 flash
My flash doesnt work either. Holding the flash button down doesnt do anything either (in program mode)
Apr 08, 2008 | Canon PowerShot G9 Digital Camera
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
Aug 18, 2007 | Canon PowerShot A630 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
19 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
