Question about Memorex Office Equipment & Supplies
Need 64 bit Vista driver for Memorex 6136u flat bed scanner
  • 111 Answers
SOURCE: vista 64 bit
The D660U is not supported in a 64 bit OS. Only the 32 bit version of Windows Vista is supported. You can get that driver here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6629
Let's face it, the D660U was released in September of 2000. That's nearly 7 years ago. You can say "Shame on all vendors" all you want. However, I'll bet that the computer you have Windows Vista64 running on is not the same computer you had when you bought the D660U. It's time to upgrade. The CanoScan 8800F is a great scanner. Amazingly fast too! Zero warm-up time.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=120&modelid=15561
Good luck.
Posted on May 22, 2008
SOURCE: I have a Memorex U48
get the winXP driver MEMu1.50 (still available), there are no Vista drivers. Run the installation using WinXP emulation in Vista. You must run the installation as if you are in XP, not necessary when using the scanner subsequently. Now the Memorex 48u works on a Dell Dimension, running Windows Vista Home Premium. Hope this helps. I got the scannner for $14 after rebates at Staples years ago, it won't die.
Posted on Sep 14, 2008
niquose
  • 198 Answers
SOURCE: MEM48U drivers for VISTA
here you go:
http://www.bioticaindia.com/mem48u.html
Posted on Jun 25, 2009
MarcusVR
SOURCE: CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Posted on Jan 16, 2010
SOURCE: Mustek Be@rPaw Scanner 1200CS Drivers for Vista x64 bit
help me download driver on windows vista 64bit.. thanks..
Posted on Feb 07, 2010
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
I need a driver for my scanner running on XP
I'm guessing the 6136U stands for USB. If that's the case, try the following http://www.memorex.com/archives/discontinued/show_product.php?p=882 and click on the software download.
If you're trying to run this on a model higher than W-2000, you need to run the software in 2000 compatibility mode unless the drivers just happen to work all by itself.
Carl
Feb 04, 2010 | Computers & Internet
I have a memorex 6142u w/ no vista drivers???
This solution worked for me. I have 64-bit version of Vista. If you have 64-bit version of Vista this is the only thing that I have found to work.
What I did was used a different scanners driver for my Memorex 6142u. I used the Hamrick version of the Canon N1220U scanner driver. The best way to do this is to plug the USB cord into the computer. Vista will try and find the driver for you and fail. then go to device manager. It will say that it isn't working properly. Then fix the driver by selecting from the list of drivers that Vista has packaged with it.
Jan 26, 2009 | Memorex MEM48U Flatbed Scanner
I hae a memorex 6142u w/ no vista drivers???
Go to site http://support.visioneer.com/products/home/EOL/Memorex/
Download/save application file 6142. Check file properties, under compatibility select "run this program..." and choose Windows XP(Service Pack 2). if u do not have a vista option
Then run the program.
Good Luck
Canoscan does not work on vista 64-bit
I'm not sure if this will work on the lide 20. I have an lide 35, and there are no 64 bit drivers for it. I downloaded and installed the drivers for the lide 60, told the computer to manually find the lide 60 drivers for my scanner, and installed the canoscan toolbox for vista 64 bit. Works like a champ.
Nov 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
I have a Memorex U48 Flat Bed Scanner and have bought a new compouter with Vista. I need a driver download to work with Windows Vista. Thanks jreowens@aol.com
May 05, 2008 | Memorex MEM48U Flatbed Scanner
569 people viewed this question
Top Memorex Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Memorex Office Equipment and Supply Expert? Answer questions, earn points and help others
