Question about Whirlpool LHW0050PQ Front Load Washer
The machine keeps indicating a closed water tap! very little water entering the drum.
  • 76 Answers
Chek ur whater temp on ur sicle and then if dont work just turn the taps fuul power
Posted on Nov 19, 2009
Lets in to little water
Washing machines work a little like when filling up the car with fuel. If you feed it in too fast it keeps stopping delivering. Try reducing the water pressure coming into the machine by throttling back hose inlet at the tap by closing it slightly. Will take a second or two longer to fill but will allow more water in before cutting off.
Sep 21, 2015 | Washing Machines
What dose the NF means
Hi Kathy, the NF code means No Fill which indicates water is not passing to the drum, this could be the water taps are off or blocked or the door is not shut properly so stopping the water from entering! Have you just installed or was it running previously?
Oct 25, 2014 | Washing Machines
Aeg 60870 dishwasher water not getting in. Error code.10
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Oct 04, 2014 | AEG Dishwashers
My Jura Capresso E 8 is stuck in open tap filling system. I open tap it says filling system, it says close tap, when I close the tap it goes back into open tap. Float valve looks fine, water is moving
Open the tap with frother spout off. This happened to mine and I took the frother tip off and opened tap with tip off. Water filled and I closed tap...Machine returned "Ready". I heated water in microwave for three minutes- placed frother tip in hot water and all kinds of gunk came out. Lesson learned- Do a thorough cleaning of frother by immersing it in very hot water at least once monthly- even if you don't use it
Jan 06, 2013 | Jura Capresso Impressa E8 Espresso/Coffee...
I am getting water in the drum. At first I thought it wasn't pumping the water out, but last night, I heard a continued beeping sound, and it was flashing "do" on the little screen and the...
Remove power completely AND turn of either the hot or cold tap/fawcet and see what happens. If no water being fed into drum turn the tap which is off back on and see. If water is being fed in again then it is symptomatic of a malfunctioning whichever water control valve not closing completely- its default/no power position. Sorry but it needs replacing.
If water is only being fed in when there is power on it could be the control board feeding the incorrect voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 01, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
We are getting a sound that the pump is running but no water in entering the drum and we are getting a FH signal readout. we have followed the troubleshooting booklet. Is it possible the pump is bad?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Aug 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machine keeps stopping and says "water tap closed?"
Wonderful!! Would you mind giving me a "problem solved" rating -- there should be icons on the screen to do that.
thanks...
Charlie
May 29, 2009 | Maytag LSE7806A Top Load Stacked...
Fabric condtioner won't go through into drum during rinse cycle
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
May 25, 2009 | Candy AQ130 Front Load Washer
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
Miele Premier Novo Washing Machine: Water coming straight out of the machine
The lower left panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or Tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Clean out any debris and reassemble. If the filter is not seating properly in its seat - water will leak from the small hose - the filter is what blocks the water from coming out of the hose.
Apr 05, 2008 | Miele Novotronic Premier 500 Front Load...
Whirlpool LHW0050PQ Front Load Washer Logo
236 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
