Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Only one voice coil is working on my L7 10" sub? All connections look good. 2 2ohm subs wired to 2ohms with a Kicker zx1000.1 mono amp. why?
    Problem Solver:
  • 12 Answers
If the tinsil wires all look good then chances are you broke a lead in the coil, the only way I know of to fix this is to order new voice coils and a new spider and replace them..
There are places on the web to order parts, you just need to take good measurments of the parts and relay them to the stores.
Posted on Mar 08, 2010
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
Hello oran1891,
OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
Hope this helps.
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
How do you wire 4 kicker cvr dual voice coil 4ohms to a 1500.1 kicker mono block 1 channel amp, they sound distorted when i turn them up, how should i wire them?
Hello antjobe,
According to Kicker the 1500.1 is only stable to 2ohms. So you will want your 4 CVR's to present a 2ohm or higher impedance to the amp.
The best configuration would be to wire the voice coils in series (each sub 8ohms) and then parallel all of the subs to the amp (2ohms). Here's a link to the diagram.
Hope this helps.
Jun 08, 2009 | Kicker CVR12 Car Subwoofer
I need to know how to bridge a a 4 ohm 15 inch sub down to1or2ohm
Hello solo7908,
With a single 4ohm DVC sub there are only two possible wiring solutions, parallel the voice coils for a final 2ohm load or series the voice coils for an 8ohm load. In your case, you want to wire them in parallel, both positives and both negatives connected to the amp terminals.
Here are the diagrams: (-) to (-) and then to the amp - (+) to (+) and then to the amp. Impedance = 2ohms.
Hope this helps.
Jun 06, 2009 | Kicker CompVR 12" Subwoofers/Enclosure...
Sony xm-D9001GTR mono and kicker 4ohm dual voice coil
its a good amp but dont power ur amp at full put it at about half power
May 27, 2009 | Sony XMD9001GTR Car Audio Amplifier
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
I have 2 kicker 07CVR124 12" dual voice coil with a 800 watt mono pioneer amp. How do I wire it correctly
I'm not sure what pinoeer amp you have. If I remember correctly some are 1 ohm stable. In this case you would be able to wire everything in parallel. Meaning, with the voice coil, wire the positive to positive, and the negative to negative. Then wire the subs together positive to positive, and negative to negative. This will give you the total impedence of 1 ohm. If it isn't 1 ohm stable the best you could do is 4 ohms. To do this you would need to wire the voice coils in series and the subs in parallel. Meaning, wire the negative to positive and the positive to negative. Then take the subs and connect the positive to positive and the negative to negative. I hope this isn't too confusing. If you need further assistance let me know. Good luck
-Andrew Hawkins
Aug 26, 2008 | Kicker Car Audio & Video
Subs
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Aug 23, 2008 | Legend LA1490 - American Legacy Series 2 -...
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
173 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
