Question about Panasonic KX-T7730 Corded Phone
Answering the phone
How do I answer the phone from another extension when the switchboard is busy?
  • 113 Answers
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 to answer external incommincg calls. To answer extension phone press 4 followed by the extension number.
Thank you
Posted on Mar 29, 2010
2 Suggested Answers
Phonesmith
  • 113 Answers
SOURCE: Answering
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 for an external incomming call or 4 followed by the extension number to pick up a certain extension that is ringing.
Thank you.
Testimonial: "Thank you very much!! Problem solved!!"
AT&T 5840 5.8GHz
try reseting the phone by unpluging it and also removeing the batterys. Il check the manual.
Aug 23, 2008 | AT&T 5840 5.8GHz...
How to assign extention bottons on a KX-T7636
Do you have programming software?
I will gladly guide you through.
Feb 06, 2013 | Panasonic KX-T7636W Corded Phone
Nortel startalk one of my extensions keeps getting calls and when answered there is just a busy signal on the other end. What is causing this?
If answering live call and is busy signal on the other end then could be a recording from far end....call a tech in.
If voice mail message is busy signal it could be same as above or Disconnect Supervsision is not programmed on the lines and with the carrier.....this detects when caller hangs up then system knows to hang up, if does not hangup then you get busy signal.
Oct 24, 2012 | NorStar Startalk Flash 2 Phone
If I get this AT&T 1739 answering machine will it retreive messages when I am on the phone with someone else, also can I record my own message on it for my business
Without call waiting or a second line, callers will get a busy signal if you're already on a call. This happens at the switchboard; it doesn't matter what type of answering machine you have because the second call doesn't get that far.
You can record your own message on the 1739 but, as mentioned above, if you're already on a call then the second call never gets that far.
Mar 08, 2012 | AT&T ATT1739 Digital Answering Machine
Answering
Thank you.
Mar 25, 2010 | Panasonic KX-T7730 Corded Phone
Have a new all in one printer (print, fax, scan and copy) feature
Here's where a Panasonic TA-824 would work great. At a street price of about $200, you can control your 3 lines and up to 8 extensions, one of them being your fax machine that would have access from both lines, and an answering machine that could take messages.
Some of the fax machines can detect a fax tone on a phone line, so you could have the answering machine answer the call and you tell them to press send (or it listens for a CNG tone, but the fax machine is limited to only one line.
Carl
Apr 01, 2009 | Panasonic KX-TG2740 Cordless Phone
Don't know how to retrieve messages. (Extension is main switch)
Is that like when she says you have no new messages, To receive the messages press "1"? Press 1.
Carl
Mar 20, 2009 | Panasonic KX-T7630 Corded Phone
HOW TO CANCEL A DIVERT FROM ANOTHER EXTENSION NUMBER
no you cannot prevent this from the attendant console.aa is not normally set up.your installer needs to change the class of service of your extension to stop forward no answer. if the other phone/office is unoccupied try leaving it off the hook,your own phone may not want to forward when the other one is busy...i hope this helps
Dec 16, 2008 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
Can I use this fax on a telephone line together with a GE 2.4 GHz Cordless Telephone (Model 27992B)? Will it be possible to recive messages and faxes when no one is at home? Remark: The answering machine...
sure u can: Installation with an answering machine and/or extension telephone: 1. Remove the seal covering the TEL. SET jack on the rear of the fax. Connect an extension telephone or answering machine to the TEL. SET jack. 2. If desired, connect an extension phone to the answering machine. from the user Fax guide: If desired,you can also connect an answering machine or an extension telephone to your fax. ¨ Connecting an answering machine to the fax will allow you to receive both voice and fax messages on the same line while you are out. For details on using this feature, see Chapter 7. (Note: Do not connect an answering machine to your fax if you will be using the distinctive ring feature described in Chapter 2.) ¨ You can connect an extension phone to the fax to make and receive calls like any other extension phone on your line.
Oct 09, 2005 | Sharp UX 510 Plain Paper Thermal transfer...
Panasonic KX-T7730 Corded Phone Logo
116 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
